Clunk when accelerating from stop
2011 F150, 6.2, 4x4, 29k miles. When accelerating from a stop I get a "clunk" noise in the drive train. I had this same issue/feeling with my F250 and greased the slip joint in the drive shaft. It fixed the issue.
Only problem is, my F150 is a one piece driveshaft. Any ideas?
Thanks for the link but I have a one piece drive shaft. Just crawled under it to confirm.
However, when I was under it I noticed transmission fluid leaking out of the front. Most likely the front seal. The first 3 days I had the truck the LS clutch packs had to be replaced as well. Starting to think I bought a lemon. So I am probably going to take it back to the dealer and see what they can find, which is another 3 hour one way drive...
but if the splined connection between the transfer case and driveshaft (aka slip joint) gets dry it will exhibit the same symptoms as the TSB describes.
that is to say: just because ford hasn't issued a TSB for it, does not mean that the condition does not exist.
i'd grease the output shaft and see if that fixes ya up.
Clunk in Drive Train
This is what i think, Most Fords have Backlash in the Rear Differential Case when you come to a stop, not all the time, when you take your foot off of the brake and accelerate you will sometimes get a clunk this is this Backlash that you feel in the drivetrain,I also have a one piece drive shaft
Amicus
28
09-23-2018 08:02 PM
UP77F250
20
04-09-2013 11:46 AM
