Clunk when accelerating from stop - Ford Truck Enthusiasts Forums
Old 06-24-2014, 04:29 PM
kameronth's Avatar
kameronth kameronth is offline
kameronth is gaining momentum as a positive member of FTE.
2011 F150, 6.2, 4x4, 29k miles. When accelerating from a stop I get a "clunk" noise in the drive train. I had this same issue/feeling with my F250 and greased the slip joint in the drive shaft. It fixed the issue.
Only problem is, my F150 is a one piece driveshaft. Any ideas?
Old 06-24-2014, 08:19 PM
gDMJoe's Avatar
gDMJoe gDMJoe is offline
gDMJoe has a very good reputation on FTE.gDMJoe has a very good reputation on FTE.gDMJoe has a very good reputation on FTE.
VIBRATION/THUMP/CLUNK NOISE ...TSB 13-3-13 ллл -click-
-click- the pic'
Goth 150
< This space intentionally -blank- >
Old 06-24-2014, 09:04 PM
kameronth's Avatar
Thanks for the link but I have a one piece drive shaft. Just crawled under it to confirm.
However, when I was under it I noticed transmission fluid leaking out of the front. Most likely the front seal. The first 3 days I had the truck the LS clutch packs had to be replaced as well. Starting to think I bought a lemon. So I am probably going to take it back to the dealer and see what they can find, which is another 3 hour one way drive...
Old 06-24-2014, 09:27 PM
meborder's Avatar
meborder meborder is offline
meborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant future
a 1 piece drive shaft will still have a slip joint.
typically the transmission output shaft acts as the slip joint in this arrangement.
Old 06-24-2014, 09:31 PM
kameronth's Avatar
Yes but I don't have a center support bearing like that link talks about. Mine has a splined shaft that slides into the rear of the transfer case.
Old 06-24-2014, 09:58 PM
meborder's Avatar
10-4
but if the splined connection between the transfer case and driveshaft (aka slip joint) gets dry it will exhibit the same symptoms as the TSB describes.
that is to say: just because ford hasn't issued a TSB for it, does not mean that the condition does not exist.
i'd grease the output shaft and see if that fixes ya up.
Old 06-24-2014, 10:02 PM
kameronth's Avatar
I was thinking that could be it as well. I'll try and pull it apart tomorrow and see what happens. Is the transfer case a sealed unit or is fluid going to pour out of it when I pull the slip joint out?
Old 06-25-2014, 10:07 AM
meborder's Avatar
that, my friend, is a very good question.
I would think it is sealed, but i don't know for sure 100%.
methinks that the outer seal is just to keep dirt out, but not to keep fluid in. there should be an inner seal for the fluid.
maybe someone who as dropped thier driveshaft can confirm?
Old 06-25-2014, 10:50 AM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
The transfer case fluid lubes the slip joint. If you pull the driveshaft then the fluid will come out. There is no inner seal for the fluid.
Old 06-25-2014, 01:44 PM
ecoboost12 ecoboost12 is offline
ecoboost12 is starting off with a positive reputation.
Clunk in Drive Train
This is what i think, Most Fords have Backlash in the Rear Differential Case when you come to a stop, not all the time, when you take your foot off of the brake and accelerate you will sometimes get a clunk this is this Backlash that you feel in the drivetrain,I also have a one piece drive shaft
Old 06-25-2014, 02:33 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Unless the case is OVERFULL you will only lose a small amount of fluid.
Old 06-25-2014, 11:52 PM
kameronth's Avatar
I'm going to drive it back to the dealer this weekend and let them try and figure it out. The clunk is more than just normal backlash due to the one piece driveshaft. My work truck is the same set up but with the 5.0. It hasn't and doesn't clunk at all.
Old 06-26-2014, 08:40 AM
FordService's Avatar
FordService FordService is offline
Official Ford Rep
FordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud of
Quote:
Originally Posted by kameronth View Post
I'm going to drive it back to the dealer this weekend and let them try and figure it out...
Good idea, kameronth. Let us know when you get a verdict; I'll hang around this thread in case you need my help.
Crystal
Old 07-16-2014, 03:24 PM
kameronth's Avatar
After 2 1/2 weeks I finally have my new truck back. They had to pull the transmission and replace the front seal. Also, they greased the slip joint and no more clunk. Tonight I will crawl under it to get a better look at the transmission. So far all seems to be operating correctly.
Old 07-17-2014, 09:51 AM
Official Ford Rep
...So far all seems to be operating correctly.
Great news, kameronth! I'm glad to hear that your truck is back at home. If I can be of any assistance in the future, just let me know.
Crystal
Clunk when taking off from a stop. ??? knightrider955 1999 to 2016 Super Duty 25 05-16-2016 08:19 PM
Clunking/Bumps Masshuu 1997 - 2003 F150 9 05-25-2014 12:18 PM
Scary clunk in drivetrain DBreedlove 1999 to 2016 Super Duty 24 04-07-2014 10:49 AM
99 Explorer clunking on acceleration corky43 Explorer, Sport Trac, Mountaineer & Aviator 2 03-26-2009 03:58 PM
Clunking when accelerating and letting off mrl390 1987 - 1996 F150 & Larger F-Series Trucks 8 09-22-2006 10:04 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
