Rough Idle,sluggish
Old 06-24-2014, 10:45 AM
scotty088's Avatar
scotty088
scotty088 is offline
Rough Idle,sluggish
My 6.0 has 73k miles factory stock, I'm the original owner. Now has a erratic idle and seems sluggish. No m.i.l. I change Engine oil every 5500 miles.I have changed Fuel filters every 3rd oil change.I'm wondering if may have got some bad fuel and need to change out filters.My question is why do auto parts stores have such a drastic price difference in filters.Napa for example 21.95 for cheap and 92.95 for Gold Filters.Is there really that much difference?
Old 06-24-2014, 11:22 AM
jswartz84's Avatar
jswartz84
jswartz84 is offline
Yes there is. Only use OEM filters, or Racor. Filters are cheap compared to replacing a motor.
Old 06-24-2014, 11:29 AM
Money-Pit's Avatar
Money-Pit
Money-Pit is offline
The only way to correctly determine your idle and running problems is with something like a ScangaugeII or something similiar to read various sensors on the motor.
I buy my filters online from here for a good price. $35.75 for both fuel filters & $13.95 for the oil filter. (and they are the correct ones to use. Racor brand is cheaper and is the company that makes the Motorcraft fuel & oil filters)
Ford 6.0 Liter Turbo Diesel Truck Filters, Air Filters, Oil Filters, Transmission Filters And Glow Plugs - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
Old 06-24-2014, 11:45 AM
TxMav's Avatar
TxMav
TxMav is offline
I don't know if you have Advance Auto Supply in your area but they are pretty reasonably priced for OEM Filters. If you order online, there is usually a discount code that you can use to get 10-15% off. Then you can drive in and pick up at the nearest location. The last time I bought OEM fuel filters for $39.19.
Motorcraft Fuel Filter
Part No FD-4616
Advance Auto Parts: Car, Engine, Batteries, Brakes, Replacement, Performance & Accessories
Hope that helps.
Trigger johansen
04-13-2011 03:59 PM
lewis racing
08-03-2010 02:15 PM
Fandini
04-11-2010 09:15 AM
riverrat41
17
09-09-2009 10:05 AM
kirkharrod
06-15-2009 04:08 PM
Quick Reply: Rough Idle,sluggish
