My cam phasers are switched - is this ok? - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 06-24-2014, 08:05 AM
blue70beetle blue70beetle is offline
blue70beetle is starting off with a positive reputation.
'07 Navigator; clatter at startup, quiet while running. 120k miles. I recently got this vehicle and I don't know its history.
I pulled the covers off and found the left bank had a small chunk broken off the tensioning guide, so I assume the tensioners are bad, allowing the chains to slap at startup.
The biggest concern, though, was that the phasers are stamped L on the passenger side and R on the driver's side. From what I can tell, some aftermarket phasers aren't sold bank-specific, so it could be that they've been replaced in the past and I don't have an issue at all, but I wanted to verify with someone more familiar with this engine than me.
Since the phasers aren't ticking and appear to be in good condition (apart from their locations being reversed), do I need to do anything with them? I'm inclined to just line up the new chains with the marks and put it back together.
Old 06-24-2014, 12:21 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
The phasers have a L and a R on each one, they are the same part for both sides. Turn the engine 360 degrees and you will see the other marks. Read my posts in this thread to set the chains up properly.
Old 06-26-2014, 08:43 AM
Thanks for the input. I found that there were marks on the other side like you said, and I had removed the chains with #1 TDC exhaust. I reinstalled the chains, turned the crank 360 degrees, saw the correct marks on the phasers, and installed the new chains without issue. I counted links to be sure it was timed right, turned the engine over by hand several times, and counted links again just to be sure.
Now I'm in the process of putting it all back together which, so far, seems to be going faster than taking it apart...
How to Save Installing 18 of 24 Followers on a Timing Job. macubus 2004 - 2008 F150 5 02-05-2017 03:08 PM
Timing chains super tight paintslinga2010 Modular V8 (4.6L, 5.4L) 1 03-20-2016 09:41 PM
Timing chains too tight? paintslinga2010 2004 - 2008 F150 4 03-15-2016 11:03 PM
Rattle on Startup Shadow351 2004 - 2008 F150 11 12-13-2015 03:25 PM
Cam Phaser / Timing Component Replacement Help Needed jrroth 2004 - 2008 F150 6 09-17-2013 06:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
