mid 80's clutch pressure plate rating 10" vs 11" ??? - Ford Truck Enthusiasts Forums
Old 06-23-2014, 11:09 PM
Econo4spd Econo4spd is offline
Econo4spd is starting off with a positive reputation.
I have a 4 spd OD RUG box behind a 300-6 4.9L in a 1985 Econoline with stock 10" clutch, but the flywheel is drilled for an 11" also.
I'm looking for a performance upgrade, but...
When Ford changed to a hydr clutch pedal on the van, they mounted the master cyl to the sheet metal floor. Not so durable. I had to weld my floor up and double skinned it. I don't want to increase pedal force much because of that.
Does the stock 11" clutch have much more pedal force than the 10"? I see ford used the same master/ slave for both the 10" & 11" clutch (according to RockAuto listing).
Any other recommendations?
Summit lists a Zoom MU30-1 with this generic marketing blurb
"These Zoom MU Series clutches by Perfection are OEM replacement clutch kits that provide more grip without the stiff pedal of most aftermarket clutches."
How much more grip?
Thanks.
Old 06-23-2014, 11:28 PM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
I had that same set up. No clutch troubles other than the floor flex, for which I made a reinforcement. I wouldn't fiddle with it--you will find the next weak link in the drive train, which may be that OD trans.
I planned to swap a T5 into mine but never got to it. I had 3.50s and 31" tires--a bit of a pooch and 2nd to 3rd sucked.
Sometimes I miss that trans, so I just skip gears in my current 5 speed and shift at 2800 rpms......
Old 06-24-2014, 01:38 PM
Carolina Clutch sez pedal effort similar
Thanks for the input.
I'm rebuilding the box now.
My rear has a 3.0. Probably go to a 3.3 or 3.5 after I get the torque curve figured out at cruise RPM.
What kind of MPG did you get w/ the 3.5s I can hardly use OD unless I'm going 70?
searching the other posts I found reference to Carolina Clutch and sent them an email. Just got a reply....
"As long as you have the mechanical rel brg which the clutch fork slides into you can
use either 10 or 11. The pedal effort on either should be very similar"
Tom Haus
Carolina Clutch and Performance, Inc.: Performance Clutches &amp Flywheels
888-462-2739
Last edited by Econo4spd; 06-24-2014 at 01:49 PM. Reason: found add'l info from vendor
Old 06-24-2014, 02:45 PM
I might have gotten 18 or 19 once. I seem to recall 13 once. The tires really goofed it up, other than they looked lot better than the stock donuts. I never really tracked it. I drove it about 10000 miles between 1991 or 2 and 2009. Getting married and having kids changed a lot of plans.....
Need Clutch Advice - Don't want South Bend carguy3j 1999 - 2003 7.3L Power Stroke Diesel 15 07-20-2016 10:21 PM
Ford 460 engine needing a good old 12" clutch bell housing. ezsqueez 1973 - 1979 F-100 & Larger F-Series Trucks 0 12-04-2015 07:04 PM
'77 f150 clutch shorty2tall 1973 - 1979 F-100 & Larger F-Series Trucks 0 11-07-2011 12:20 AM
What clutch and where to get it? 91Bronc300 1973 - 1979 F-100 & Larger F-Series Trucks 4 10-14-2010 07:55 PM
10" to 11" clutch questions... hayden01 Clutch, Transmission, Differential, Axle & Transfer Case 2 11-09-2009 01:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
