6.7L EGT off the charts, stutter'd then died
Old 07-13-2014, 07:44 AM
F350 1990's Avatar
F350 1990
F350 1990 is offline
So -- I load up the trailer on the 2011 6.7L (56,000 miles) this morning, head out onto the interstate for some Sunday fun and in the "middle" of a regen my Torque App (EGT) temp shoots up violently, the truck stutter steps, downshifts HARD and I'm bingo ground speed and have to pull over as the engine dies, quite catastrophically -- since I work on vehicles and have a shop I know better than to try cranking it after this type of "event", so I call AAA and have them tow it off to the dealership's service bay entrance.
As background, this vehicle has already been back to the dealership (under warranty) five times for replacement of the turbo, fuel pump, computer, and various diagnostic codes issues. I'm not particularly pleased with the fuel mileage and today's problem makes me think it's time to investigate a lemon type issue with the dealership.
I'm pretty confident that something internal went haywire in the engine (e.g. valve), but since it's still under warranty (100,000) I'm letting the dealer "deal" with it --- should it end being in the engine internals I may just leave it with the dealership and pursue a lemon charge against Ford.
Old 07-13-2014, 08:18 AM
EO2SeaBee's Avatar
EO2SeaBee
EO2SeaBee is offline
There have been several reports of bad EGT sensors causing that exact thing. Replace the sensor, reset the code and get back on the road. It's bad enough that a lot of guys are carrying spares on board, along with the tools to change it roadside. Should not be a big deal getting you back on the road. Sorry for the bad luck.
Old 07-13-2014, 10:03 AM
senix's Avatar
senix
senix is offline
Received 1,398 Likes on 995 Posts
keep us posted but my bet is on the sensor as well.
Old 07-14-2014, 11:16 AM
F350 1990's Avatar
F350 1990
Scratch one engine ---they tore into it this morning and it took out an exhaust valve............apparently an exhaust superheat (during regen)..........looks like Ford is buying an engine.
Let's hope I get a newer year's version..........because 2011's 6.7L is a PROBLEM
Old 07-14-2014, 12:10 PM
GW09F350's Avatar
GW09F350
GW09F350 is offline
Bummer! I hate dealing with any kind of vehicle problems, especially major ones on the road!... Glad for you that at least this will be on Fords "Dime"...
Old 07-14-2014, 05:45 PM
PlayersZ28's Avatar
PlayersZ28
PlayersZ28 is offline
Do you know what the EGT got to? I better start towing with mine so that if it's going to fail it does it under warranty 69000km (43,000mi) on it now.
Old 07-14-2014, 06:08 PM
BigF350's Avatar
BigF350
BigF350 is offline
I was going to guess exhaust valve. That's a bummer. Glad to hear its all covered. Let us know how you go
Old 07-14-2014, 06:13 PM
Dakster's Avatar
Dakster
Dakster is offline
Unfortunately you sucked an exhaust valve. More common on the c&c's, but an occasional pickup has had that happen as well.
Look at this way - you are getting a new motor.... If you are worried about it, then this might be the time to trade it in.
Old 07-15-2014, 06:26 AM
System's Avatar
System
System is offline
Prolocutor
Received 1,183 Likes on 568 Posts
X2. Everyone's different and odds are new motor will be perfectly fine, but I would use this as an excuse to get a 15. Not because I would worry about the motor but because I love excuses to get new toys... Keep us posted on how it turns out...
Old 07-15-2014, 01:15 PM
my_crib_too's Avatar
my_crib_too
my_crib_too is offline
Received 1,183 Likes on 364 Posts
Still thinking about using the lemon law? Trading the truck?
Old 07-15-2014, 06:43 PM
SandR's Avatar
SandR
SandR is offline
Originally Posted by PlayersZ28
Do you know what the EGT got to?.
I am curious. I see 1200 on the highway during regen. Recently while towing I was coming into Wilmington when a regen process started. As I began to get into stop and go traffic EGT4 hit 1526 on my Edge insight. I have never seen it that high.
Old 07-15-2014, 07:07 PM
Lastwagen's Avatar
Lastwagen
Lastwagen is offline
EGT 4 sensor is the end of the line sensor. Which means the exhaust temp out the tailpipe was close to 1500. Your exhaust tip would have been dull cherry red which is around 1470. I've never seen EGT 4 above 1200. That should burn some soot...
Old 07-15-2014, 07:34 PM
gsxr1300's Avatar
gsxr1300
gsxr1300 is offline
I saw1500 on EGT 4 last week during a regen while towing my 5 er through the mountains in VT.
Old 07-15-2014, 09:00 PM
Romeo Scorpion's Avatar
Romeo Scorpion
Romeo Scorpion is offline
I saw 1410 once, 1350+ several times.
I think the regen system can be caught by surprise under the right conditions. Whenever that happens, you can see both EGT 1 & 2 dropping rapidly in an attempt to get the temps under control. Too bad it can't actually regen at those temps. My CTS shows the soot level dropping 2-3 counts per second at 1390 degrees. That would certainly be a quick regen!
Old 07-15-2014, 09:32 PM
Glockin' Bob's Avatar
Glockin' Bob
Glockin' Bob is offline
Wow, temperatures in excess of 1500 F., has me wondering if there isn't a flaw in the system design. Even modern valve alloys can't handle those kind of temperatures without serious loss of longevity. May be the metallurgy of the valves, but could also be a head design issue or a flaw in the regen control system causing these exhaust valve failures.
Quick Reply: 6.7L EGT off the charts, stutter'd then died
