F100 Crown Vic 460 Viking Build - Ford Truck Enthusiasts Forums
Old 06-23-2014, 08:38 PM
pauli3wood's Avatar
pauli3wood pauli3wood is offline
pauli3wood is starting off with a positive reputation.
This thread will replace the previous thread "1977 F100 Single Cab Project"
This is a COMPLETE rebuild of my Grandfather's 1977 Short Bed F100.
Donor Cab
The Hammer Battalion. This is about the time when we decided to do complete teardown. Davewild's thread was inspiration to perform a CV Swap. The 460 from the monster will go in the F100.
Mock up.
Shuffling parts.
Grinding and drilling rivets.
We decided to box the frame with a C section and not weld on the frame itself.
Beefy crossmember.
This allowed us to use the factory radius arm bushing. I never took a picture of the bracket that is bolted to the frame. I will soon.
Metal parts ready for media blasting.
Finished C section.
Epoxy primer
Herculiner
All bare metal was epoxy primer and single stage urethane.
Old 06-23-2014, 10:10 PM
blue04.5's Avatar
blue04.5 blue04.5 is offline
blue04.5 is gaining momentum as a positive member of FTE.blue04.5 is gaining momentum as a positive member of FTE.
Nice, thanks for taking the time to take all the pictures as well.
Old 06-24-2014, 01:08 AM
jason77F250's Avatar
jason77F250 jason77F250 is offline
jason77F250 is starting off with a positive reputation.
You do some impressive work man. Thanks for sharing all those pics.
Old 06-24-2014, 11:03 AM
pauli3wood's Avatar
Radius / Control Arm bracket. This allowed us to use the stock style bushings.
Another angle before paint.
Old 06-24-2014, 11:08 AM
pauli3wood's Avatar
Quote:
I have worked with 78_f800crewcab4x4 for everything on this build. HIS work is impressive.
Old 06-24-2014, 12:16 PM
fordcrzymike's Avatar
fordcrzymike fordcrzymike is offline
fordcrzymike is gaining momentum as a positive member of FTE.fordcrzymike is gaining momentum as a positive member of FTE.
Great build so far! Looking really good! If it was me, I'd be halfway tempted to drop in a modular V8.
Old 06-24-2014, 03:08 PM
redroad's Avatar
redroad redroad is offline
redroad has a good reputation on FTE.redroad has a good reputation on FTE.
Really nice work fellas
Old 06-24-2014, 11:58 PM
pauli3wood's Avatar
Factory F100 leaf springs
Oxy Acetylene Torch for bushing removal
After degreasing, marine clean, and metal prep and ready.
Ready for POR 15
Old 06-25-2014, 01:38 AM
EP145's Avatar
EP145 EP145 is offline
EP145 is starting off with a positive reputation.
Great pictures! And excellent job on the frame work.
Old 06-25-2014, 02:17 AM
blackjack33's Avatar
blackjack33 blackjack33 is offline
blackjack33 is gaining momentum as a positive member of FTE.blackjack33 is gaining momentum as a positive member of FTE.
Tagging this thread.
Nice work!
Old 06-25-2014, 05:47 AM
trozei's Avatar
trozei trozei is offline
trozei has a great reputation on FTE.trozei has a great reputation on FTE.trozei has a great reputation on FTE.trozei has a great reputation on FTE.trozei has a great reputation on FTE.
I love the work you've done so far and I really appreciate the good photos.
Old 06-25-2014, 10:36 PM
1FastGambler 1FastGambler is offline
1FastGambler is starting off with a positive reputation.
Great work! Can't wait to see this to completion.
Old 06-26-2014, 02:07 AM
pauli3wood's Avatar
Old 06-26-2014, 06:01 AM
trozei's Avatar
Is that your very truck?
Old 06-26-2014, 03:51 PM
pauli3wood's Avatar
Quote:
No. Someone posted it a while back. Love the color of my truck and you don't see it too often.
Found some 1978 Bronco Low Back seats. Will modify the brackets, reupholster, and use in the F100.
1982 150 XLT Lariat 4X4 Value Youthdude 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 27 12-23-2016 09:10 PM
Caution Ford GT Porn chruby99 General Automotive Discussion 8 12-20-2016 09:27 PM
Finally! drivesprocket 2017 Super Duty 17 09-09-2016 10:15 AM
Finally a Ford Truck Owner again jmaysnc New Member Introductions 7 02-08-2016 08:11 PM
First Pic's of my 50 F1 Philthy50 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 07-30-2015 04:47 PM
Tags
460, crown victoria, cv swap, f100 crown vic conversion, ford 9-inch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
