Tailgate trim install starting with nylon clips, after aligning a straight edge between the two end screws, we drilled holes for the rivets. Decided in interest of assembly and maintenance, to go with #6 screws to attach clips. Rivets can still be Used.
How do you plan to shorten the original plastic "box" for the in bed storage box... or do you have some other trick???
Looks awesome!
While you are welding in the area you may want to add a strengthing bar to the lower part of the bed below the door... it's a pretty weak section a sheet metal and I've seen mine flex when I put lots of stuff in the storage box. There was a thread somewhere on here about doing this but I can't find it.
I'm wondering what sort of tools were envisioned for the original, larger toolbox and how the modern replacements you have in mind compare to that.
The shorter toolbox just looks better.
That box will not interfere with your exhaust, will it? If I remember right you had fenderwell headers. Can't remember if you ran the pipes yet. Looking Great!
Looks awesome!
Gonna fab a metal box (previously stated a few posted back)
Thanks.
