No Turbo Sound in 1995 Powerstroke? - Ford Truck Enthusiasts Forums
Old 06-23-2014, 08:16 PM
WhiteTiger's Avatar
WhiteTiger WhiteTiger is offline
WhiteTiger is starting off with a positive reputation.
We went to look at a truck today, a 1995 powerstroke extended cab long bed 4x4 5 speed. When I test drove it, I did not hear the turbo at all, the truck seemed to have good acceleration, its my first experience with a 7.3 so Im not sure what to expect, but is it normal to not hear the turbo on these trucks or is it not spinning. there was no smoke the whole time. the truck started right up but has been sitting the last few months.
Thanks, my past experience is with the White Tiger which is a 94 351 almost identical to this one. looking to upgrade for a resto project any help would be appreciated
Old 06-23-2014, 08:26 PM
Briansshop's Avatar
Briansshop Briansshop is offline
Briansshop has a good reputation on FTE.Briansshop has a good reputation on FTE.
Pretty normal if it was stock. Won't hear it until some intake/exhaust mods.
Old 06-23-2014, 10:42 PM
WhiteTiger's Avatar
Fuel Leak
The same truck we looked at had a fuel leak near the turbo that could be smelled while driving in the truck. is this a normal leak and an easy fix?
Old 06-23-2014, 11:02 PM
Nothing Special's Avatar
Nothing Special Nothing Special is offline
Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.
I used to have an '02 PowerStroke. If I recall correctly there was a water separator or something not far from the turbo. I don't know if those leak regularly, but they do open up, so that might be a possibility. Hopefully someone with more PowerStroke experience can chime in too.
as for the turbo while, I could often hear it in mine, but it was a complete dog until the turbo started building boost. If you didn't walk away from the test drive thinking that it was the slowest thing on 4 wheels, then the turbo is working.
Old 06-23-2014, 11:11 PM
WhiteTiger's Avatar
Yea I noticed similar acceleration to my 351W, however I was honestly quite disappointed I didn't hear it as that is one of the reasons I love the sound of a diesel engine!
Old 06-23-2014, 11:22 PM
LeoJr's Avatar
LeoJr LeoJr is offline
LeoJr has a good reputation on FTE.LeoJr has a good reputation on FTE.
It took a few days before I could hear my turbo through my bone stock exhaust and factory intake. But eventually I could...assuming you didn't go to too many Who concerts, you will too. I swapped the crap leaky factory air box for a large filter, a very common mod, and I could hear the turbo a little better. But it is still a song that I hear that the rest of the family either chooses not to hear, or refuses to be enlightened...their loss.
Old 06-23-2014, 11:29 PM
WhiteTiger's Avatar
Sounds like the turbo whistle on these stock 7.3's just isn't very noticeable, which makes me feel better about this truck. Still concerned about the fuel leak but with research on the 7.3 forum on FTE it seems like its a somewhat common problem with these engines.
Old 06-26-2014, 03:33 AM
Thor'sHammer's Avatar
Thor'sHammer Thor'sHammer is offline
Thor'sHammer has a very good reputation on FTE.Thor'sHammer has a very good reputation on FTE.Thor'sHammer has a very good reputation on FTE.
There's a few o-rings on top of the engine that dry out and go bad over the years. Some examples are the fuel bowl drain valve o-rings, fuel pressure regulator seals and the fuel pump itself leaking. There are also several rubber hoses, one in particular is on the bottom of the fuel bowl and is connected to the fuel pump. It's likely rotted and leaking.
As for the turbo whistle, if it has a stock air filter housing, you won't hear it. If you purchase the truck, you should replace that housing with a 6637 or equivalent filter to REMOVE the housing from the system. It is a poor design and allows dirt to enter the engine if it's damaged or hasn't been modified by TSB. Even after the TSB had been completed, it can still leak.
1995 Powerstroke throttle response Seanosu 1994.5 - 1997 7.3L Power Stroke Diesel 37 02-09-2016 08:20 PM
1995 powerstroke engine in 1997 truck towsrus 1994.5 - 1997 7.3L Power Stroke Diesel 27 10-29-2015 10:08 PM
1995 ford powerstroke Robert Dingess 1994.5 - 1997 7.3L Power Stroke Diesel 8 06-02-2015 11:18 AM
What year? Vinford 1994.5 - 1997 7.3L Power Stroke Diesel 16 02-15-2014 09:04 AM
1995 F250 Powerstroke Towing Compacity? bens landscape 1994.5 - 1997 7.3L Power Stroke Diesel 17 02-21-2011 08:39 PM
Tags
1995, no sound, powerstroke, sound, turbo, whistle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
