Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 06-23-2014, 06:30 PM
BossFan BossFan is offline
BossFan is starting off with a positive reputation.
BossFan's '78 F250 build
I wanted to start a thread as I make fixes/updates to my í78 F250 Custom. I've owned the truck for the past three years and have slowly made some incremental improvements. When I bought the truck, it already had a 1984 351W engine it (all stock except for headers) that replaced the 300, and a 4-spd (NP-435). Truck is a 4X4 with 3.54 gears. Since purchasing the truck, Iíve made the following changes (in this order):
  • Edelbrock 1406 carburetor
  • Typhoon intake
  • Ford Racing valve covers
  • New timing chain
  • New water pump
  • Aftermarket 38-gal. fuel tank
  • New door seals
  • Aftermarket radio (fits in stock location)
  • Driveshaft balanced
  • New tires (stock size)
  • Comp cams 35-234-3 camshaft
  • Rebuilt 3-bar GT40 heads
  • Alternator (not 3G upgrade yet)
  • Starter
Truck runs good, but I never liked the homemade bends in the brake lines and last time it was on a lift, I saw that there was a lot of rust around one of the crossmembers. Last week, after reading through a lot of posts on this board, my girlfriend and I removed the bed so I could address some of the issues underneath. My current plans are as follows, and Iíve sort of broken it down into main sections:
Frame-related:
  • Replace rusty crossmember(s)
  • Replace brake line bracket (itís completely rusted off the frame)
  • Wire brush/wheel exposed frame and repaint (POR-15?)
  • Replace all brake lines with stainless
  • Replace all fuel lines with stainless
  • Replace missing bump stops (does anyone know where I can find originals?)
Transmission:
  • Remove transmission/transfer case Ė should I have these rebuilt? There doesnít seem to be any trouble with shifting but figured if it is out, maybe I should have a trans shop go through them.
  • Resurface flywheel
  • Replace clutch/throwout bearing
Engine:
  • Replace headers
  • Replace dual exhaust
  • Replace oil pan gasket (figured Iíd do this once everything is out of the way)
  • Replace engine mounts (just as a precaution since I have no idea how old they are)
Front end:
  • Rebuild front end (shocks, bushings, steering stabilizer)
  • RedHead steering box (the steering is very sloppy)
  • Replace disc brake shields (mine are almost completely rotted) Ė are these avialble? Necessary?
Miscellaneous
  • Install vintage Hurricane Turbine wheels
  • Install hitch
As I get to each of the different steps, I am sure I am going to have a lot of questions. Iíve been inspired by the work done by so many on this board and while I certainly donít have the skills of most of you, I think I can tackle a lot of this on my own, with a little help from my FTE friends.
Thanks,
Frank
This set of pics was for the bed removal:
__________________
1978 F250 4X4, 351W, 4-speed
Old 06-23-2014, 06:35 PM
some of the crossmember issues:
__________________
Old 06-23-2014, 09:48 PM
phillips91 phillips91 is offline
phillips91 is a splendid one to beholdphillips91 is a splendid one to beholdphillips91 is a splendid one to beholdphillips91 is a splendid one to beholdphillips91 is a splendid one to beholdphillips91 is a splendid one to beholdphillips91 is a splendid one to behold
Good looking truck. I thought I was the only one that used an engine lift to take the bed off a truck. Good to see I'm not alone
__________________
Josh P. Moderator Super Duty Forum
2000 F-250 5.4, manual, 4x4, 4.10 rear.
1992 Bronco 5.0, auto, 4x4, 3.73 rear
www.ford-trucks.com/guidelines.html
Old 06-24-2014, 09:06 PM
redroad's Avatar
redroad redroad is offline
redroad is gaining momentum as a positive member of FTE.redroad is gaining momentum as a positive member of FTE.
I really like your truck .. Frame is still in good shape and the parts on the frame that need work your catching it in time .. Looking forward to watching your thread
Old 06-25-2014, 12:43 AM
trozei's Avatar
trozei trozei is offline
Canadian, eh?
trozei has a good reputation on FTE.trozei has a good reputation on FTE.trozei has a good reputation on FTE.
Definitely subscribing for this.
__________________
Jackson
1969 Ford F100 300 C4 // 1973 Ford F100 Ranger 360 C6 // 2004 Ford F150 FX4 5.4L // 1995 BMW 525i
Old 06-25-2014, 05:53 AM
Thanks guys! I'm going to stop at Lowes tonight to look for an angle grinder. My plan is to start working on those rivets straight away. I'm also going to give the guys at Inline Tube a call for brake/fuel lines.
__________________
Old 06-25-2014, 05:57 AM
Just out of curiousity, if I can't find good crossmembers to replace these with, can I just replace the short 'support beams'? Not sure what they are actualy called, but it's really just those pieces that attach to the lower part of the frame that are really rotted. The top part of the crossmember is actually in really good shape.
And what's the best method to get the paint off the frame? I think I read guys will use a wire brush. I don't have a sandblaster, but am willing to buy one if that's really the best way to go.
__________________
Old 06-25-2014, 06:02 AM
Quote:
Thanks Josh
I got the idea of using the engine hoist from this forum! The only 'issue' is that the arm does not reach to the very center of the bed, so it sort of pulls the front up first and the tail of the bed gets pushed up against the 'piston' of the engine hoist. Other than that, it was really easy.
I wonder if it's possible to do something similar with the cab...I wasn't planning on removing that, but if it can be done without a front loader, I might consider it.
__________________
Old 06-25-2014, 08:58 AM
Hurricane wheels
I've got a lead on a set of Hurricane turbine wheels, however, the seller tells me thay are 14.5" wide and have a set of 35/14.5-16.5 Swamper tires. The tires are shot, and I'm not really intersetd in the tires, but are these wheels too wide for a 'stock-type' tire? Even If i just wanted to put these on 'as-is', I'm assuming I would need to lift the truck.
__________________
Old 06-25-2014, 09:40 AM
redroad's Avatar
Lifting a cab with your hoist .. On your truck you can use the seat belt tabs and hook to the cab mounts through the front window if it's out otherwise 2 forward points in the cab ..
Click the image to open in full size.
Old 06-25-2014, 09:54 AM
cool beans! Thanks!
__________________
Old 06-25-2014, 09:58 AM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to behold
Yup, that's how I pulled my cab. Did the same with the bed and I had the same problem with centering. I extended the arm out and drilled new holes. It made the hoist "end heavy" so I added some weight to the back of the hoist and made all my movements very carefully. It was on concrete.
Old 06-25-2014, 10:56 AM
redroad's Avatar
On the 16.5" x 14.5" wide wheels I'd pass just because tire choices are limited .. For all around a narrower tire will serve you better and will be less wear and tear on your front axle and steering .. BTW a 35" tire and your pretty much at the limits of what the stock Dana 44 HP front axle will handle unless you beef it up substantially ..
Old 06-25-2014, 12:10 PM
Thanks for the update on the cab lift as well as the wheel choice. I'll keep looking for a narrower set of the Hurricanes, or maybe go with the aluminum Alcoa-like wheel.
I am going to look into that cross-steering info as well. If at some point I wanted to upgrade to a Dana 60 front-end, would that impact the steering change? These are all long-term 'nice-to-have' ideas, but am just curious. This truck is never going off-road and I certainly don't 'need' a Dana 60 front-end, i'm just intrigued at the thought of doing the swap just to say I did it.
__________________
Old 06-26-2014, 02:13 AM
redroad's Avatar
The Dana 60 conversion will add quite a bit of value to the vehicle if you should decide to do it .. The value of your current high pinion 8 lug Dana 44 also has value especially if the passenger side flat top knuckle has been machined and set up for cross over steering .. The Dana 60 axle that is sought after was only made a few years so as a result they are becoming more and more scarce and more and more costly .. This has in turn had an effect on the value of the high pinion Dana 44 as a result because those driven away by the high cost of the Dana 60 are now seeking out the next best thing the HP Dana 44 .. For the guy that's not going to run anything bigger than a 35" tire and does only modest off-road stuff the HP Dana 44 is still a very good choice .. For someone who wants bigger than 35" tires and is wanting to go deep into off-roading the kingpin Dana 60 is a necessity .. It is even a must for those that use their truck for real work ..
To answer
I refer to this post by 75F350
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Want to rebuild my 460, need some assistance carver94f350 1987 - 1996 F150 & Larger F-Series Trucks 33 04-17-2014 11:56 AM
GT40 heads - do I need a new cam? BossFan Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 13 09-19-2013 11:52 PM
New Member 78 F150 4x4 78F150TX 1973 - 1979 F-100 & Larger F-Series Trucks 2 07-24-2012 11:20 PM
Loud Popping / Craking Noise Gone 93Mule 1978 - 1996 Big Bronco 4 08-22-2007 01:22 PM
Twin-I-Beam Suspension for 48-52 F-2/3 51dueller 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 03-01-2006 07:32 PM
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Fordģ is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
