BossFan's '78 F250 build
#166
#167
#168
#169
#170
#171
#173
#174
#175
SO I got my 1 5/16 for the passenger side ball joint castle nut. I'm taking tomorrow off to work on the truck. A couple of outstanding questions:
1. Still not sure how hitting the steering arm will loosen it unless the idea is to hit it from underneath
2. I dropped off my NP435 and NP205 for rebuilds. I'm assuming we are going with good axles in the front. I'm still on the fence about the engine. It ran fine, has new cam, lifters, water pump, timing chain, GT40 heads, etc. but I know nothing about the bottom end. Am I being a fool to not rebuild it while it's out?
#176
I'm guessing it's some what pressed onto the studs (?), it should pop lose with a few solid BFH hits, in either direction?
You said it ran fine, how was the oil pressure? Did you run factory oil pressure gauge or aftermarket? Which ever one, did you have good oil pressure? That is something to consider about the bottom end.
As far as a rebuild it "while it's out", well its easier to rebuild it now "while it is out", than a month later after you reinstall it....
#178
#179
Hitting it on either side will loosen it enough so you can work it with a cold chisel and hammer at the separation to get it loosenened the rest of the way ..
Putting a fresh motor in is ideal but if your going to do that then make it a 400 .. If you go that route take the knuckles and any other part you think needs cleaned with you to the machine shop with your block so they can throw it in their cleaning tank .. They should charge you only for the block ..
#180
That's why I asked "?" "Is the knuckle still mounted ?"
Do you mean do a bore and stroke or do you mean get a Ford 400? I just got good heads/cam for this 351W, not to mention just sent headers out to be coated.
