BossFan's '78 F250 build
#91
Trying to follow ..
So you have these loose ?
Next these bolts
Now under the flat spot of the bottom of the transfer case put your floor jack or whatever your using .. Temporarily lift it an inch .. Now put a piece of 3/4 " black pipe or similar across the frame right above the rear yoke of the transfer case .. From the pipe then around the yoke tie it off with a piece of rope .. Now lower the jack .. The weight of the transfer case should be temporarily secure .. The cross member should now be free to slide out the back .. Once it's free and out position your jacks to slide everything back and down and out .. First of course lift the transfer case to take loose your temporary suspension rope .. That's how I do it on my 79 ..
"Down and out"
Next these bolts
"Down and out"
#92
#93
#94
With these bolts free on both sides of the cross member slide it back past the transfer case ..
Drop one side of the cross member to the bottom lip of the frame rail while holding the other end of the cross member to the top lip of the frame rail .. In that position spin it like a propeller and your out .. You may have to convince it she's coming out with a hammer ..
Edit : My bad ! I was thinking of something else .. The cross member can only slide forward because the frame starts to narrow after that cross member when moving back .. So slide it forward over the spring shackle upper mount and past the trans .. Now drop the trans and transfer case .. With the trans and transfer case out you will now have room to remove the cross member as I described above if you need to do so to paint it if you'd like .. "Ball of confusion"
The Spinners
The Spinners
#95
#96
No way that crossmember is going to clear the front spring shackles. they sit about 1/4" off frame. Should I remove one of them? Both?
It does look like I can move the crossmember forward enough to drop the transfer case, and then slide it back enough to drop the transmission. I can’t believe it’s designed that way, but what dp I know. Is that an option, and if so, where do you separate the two? The bolts coming directly out of the transmission or where the coupler housing bolts to the transfer case?
#97
So I have to try and maneuver it over the front spring shackles?
Music for working on your truck
#98
Separate at the transfer case at the adapter housing then slide the transfer case back with your new tranny jack .. The trans output shaft slides out of the transfer case as you slide the transfer case back If you need to go that way .. You have the trans supported by the engine hoist through the shifter hole correct ?
#100
#101
DO NOT REMOVE THE FRONT SPRING SHACKLES.........
Remove the xfer case lever (the big bolt on the dvrs side that holds it to the xfer case). And get it out of your way.
If you can not get the cross member removed how ever (shot of cutting it in half lol), so you can drop trans and xfer case as one piece, then yes separate the 2.
CAUTION EACH PIECE IS HEAVY trans 120 lbs, xfer case 130 lbs.
Separate them like redroad, said use the hoist to hold the trans and the new trans jack on the xfer case, slip them apart where the middle adapter attaches to the xfer case. MAKE THAT XFER CASE IS ATTACHED (CHAINED) TO THE TRANS JACK BASE, IT CAN FLOP OFF THERE AND HURT YA IN A HEART BEAT.
Leave the trans bolted to the bell housing for now and after the xfer case is off and out, then take the adapter then the trans itself, and then remove the trans.
Sliding that dam cross member which ever way it needs to go. Having fun yet? Hang in there, see why getting to know your FTE state chapter members is such a great idea.
You did read all the PFD file I PM 'ed you right?
#102
#103
#104
#105
No idea on the paint, just a web pic so you could get a clear idea of what is where.
Sorry I do not have all the answers, like I said, hang in there unless its your DD for monday, is so you better get off the computer and get on getting that trans and transfer out. lol
