BossFan's '78 F250 build
#316
#317
Thanks redroad
THose mirrors look great and I'm sure they're excellent for towing, but I don't think I would be able to put my truck in the garage wiht them on. The mirrors I have are clearly a much later design and you can pull them in so they fold in close to the body. But the west coast ones look so much better on these trucks
#318
Thanks redroad
#319
If you like the Type 9, it folds in. My dad's got them on his Highboy. They were seized in place but I hit a road sign on the highway and broke the one loose.
Attachment 291216
Attachment 291216
#320
#321
#323
I'm still on the fence abot the whole D60 thing. I will never run any tire larger than 35" (33" will probably be more like it) and other than some occasional trail rides, I won't do any serious 'wheeling'. Of course, I want to strengthen my D44 while I have it apart, so would these be good http://www.ebay.com/itm/Ford-F250-Dana-44-Lifetime-Front-Chromoly-Axle-Shaft-Kit-78-79-w-Spicer-D44113-/390468966885?pt=Motors_Car_Truck_Parts_Accessories&hash=item5ae9c399e5&vxp=mtr?
#324
#325
#326
#327
These are the motor mount brackets that my 351W was sitting on. The one with the circle has a wallowed-out hole. I noticed when that there was a piece of steel attached to the motor mount that looked like it may have been welded on to solve this issue. Am I correct in understanding that the 'teardrop' hole on the other mount and that this should be corrected on the circled one?
For some reason, I thought that I read somewhere that these were the 300 I-6 mounts and they would cause the 351W to sit an inch or so too high. Did I read that correctly?
#328
I know that if I switch to SBF mounts, my 300 will sit an inch lower so I'm sure that's a fair assumption.
#329
Do you know if the mounts in my picture are for a 300 I-6, and if so, should I look into getting a set of SBF mounts and where would I fid them? It's a bit confusing to me b/c theses trucks never had a 302 with a 4X4 and I read somewhere else that the 302 2WD mounts are completely different animals.
#330
I bought a set of steering knuckles off of eBay that were already machined for the cross over steering. Plus, they were a lot less rusty than mine (esp. the driver side). I noticed that as I unpacked them, the steering stop bolt on the driver side is snapped (See last pic with red circle). Is that a problem?
