BossFan's '78 F250 build
#136
The lug bolt head is on the back side of the rotor and then it goes thru the rotor and thru the hub and the lug bolt splines are what locks the parts together.
A press is very much suggested to press out the lug bolts and press them back in. Putting a junk lug nut on and using a (BF) hammer to remove or or reinstall is not the best idea, due to you will not them back in as tight as they should be.
You will be tightening up your lug nuts for weeks, and a hammer is a great way to get them started crooked.
Even using a lug nut and a washer stack up and a impact. But that set up will work for trail side repairs.
That is why folks just buy the complete set up. You get new hubs with races, new rotors and new lug bolts. Also a great time to up grade lug bolts from 1/2 to 9/16, I think I am right on sizes?
Look at what I found....
#137
#139
No special tool for that. You can take a small screw driver and put a bend on the end, or a small piece of roundstock (bent and flattened out on the end), or a small pick. It is just slid on there, it pulls straight out, you will have to wiggle it from side to side.
I have a little tool like that in my toolbox, if I was home I'd post a picture of it for you.
#140
#141
#142
Its not a tool for the "wheel bearing" its a hub disassembly socket.....
Using a "spindle puller" is an good option, I mentioned that earlier. Can probably rent it at the same place to get the ball joint tool kit....so you do not mess up the threads on the end.
Once you get it off you will see how the brake shield is installed.
#143
I'm about to try and remove spindle. Once that's done (and passenger side) i want to remove the entire differential. I'm assuming I need to do the following:
1. Jack up frame and put jackstands under it
2. Drain the fluid
3. Remove steering components
4. Remove shock absorbers (jack still under differential)
5. Remove/cut u-bolts
6. Lower differential and slide out from under truck
Does that sound right? Brake lines are already removed.
2. Drain the fluid
#144
I'd just remove the complete axle (why, might I ask....anyway) and then work on removing the spindle after it is out from under the truck. Safer that way IMO.
Leave the rear tires on for stability and chock them securely! Yes jack up the truck (VERY SECURELY) far enough that the front suspension (leafs) are at full droop, and jack stand the truck (again very securely) CEMENT BLOCKS ARE NOT JACK STANDS and even put a back up fall support.
Like the front wheels and tires somewhere under the frame, say just aft of the leaf spring shackle. since your cross member is gone that's out of the question.
Only steering you have to disconnect to remove axle, is the pitman arm from the steering box. Got a tie rod fork?
Drain it later, shocks just the bottom for now, use a wire brush and lots of brake cleaner to clean the fine threads of the u-bolts, if you want to be able to reuse the u bolts later but.....
But a good idea is to just replace the u-bolts, Skyjacker sales a kit set cheap enough.
Remove calipers from rotors and use wire to hang them from frame.
Axle is HEAVY, so a floor jack plate in the middle of the axle will not work, diff throws it off balance.
Set it down on a 4x4 sheet of 3/4 ply wood and use a lawn mower to drag the ply wood....redneckin.
Ah the beginnings of a full frame off restoration start like this.
No such thing a overkill on jack stands and being careful, people get hurt OR WORSE all the time doing this stuff.
My back up is the middle post.
#145
#146
#147
I thought that if I was going to replace the axles and everything, I had to remove the differential. If it can just stay in place, then I'll leave it alone.
I did get the spindle off. Do I want to remove the axle now?
#148
#149
Yes is you are going to replace the ball joints...just pull them. You have to, to get the steering knuckle off, to get to the ball joints. The ball joints are what holds the steering knuckle on. And you have to any way to be able to replace the axle u joints.
