Replacing front tank tube assembly.
Old 06-23-2014, 01:16 PM
Groundpounder0331's Avatar
Groundpounder0331
Groundpounder0331 is offline
Hello. I disconnected my front tank supply and return fuel lines from the sending unit, and broke the connection where the supply line connects to the sender. OEM parts from the Dealer are about $188 for a new tube assembly. Anyone know a cheaper venue for this part? Part number is F5TZ-9H334-D. Thanks in advance.
Old 06-23-2014, 07:38 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
You can just cut it off and use a rubber hose with clamps. Double or triple clamps each side.
Old 06-23-2014, 08:50 PM
madpogue's Avatar
madpogue
madpogue is offline
Did you break the pickup, or the sender? The sender is attached to the pickup, but they're not "connected", per se.
Old 06-23-2014, 10:08 PM
oldbird1965
I thought he meant the quick disconnect line broke that attaches to the sender lines on the outside of the tank.
Old 06-24-2014, 12:51 AM
madpogue's Avatar
madpogue
madpogue is offline
The sender is electrical. This is what's confusing.
Old 06-24-2014, 12:17 PM
Groundpounder0331
Just to clarify... the quick disconnect clip located inside the hose where it connects to the top of the fuel tank (sending unit?) became disfigured when I removed it. I didn't use the fuel line disconnect tool correctly. I thought the entire hose had to be replaced. After bad info from the dealership saying I had to replace both hoses, my local mechanic told me you can replace the clips with NAPA aftermarket parts. Picked some up last night for a few bucks, problem solved. I almost spent $200 buying two new hoses.... My mechanic saved me some serious cash.
Old 06-24-2014, 02:55 PM
oldbird1965
That's good to know!
paddler
02-27-2017 10:59 AM
annaleigh
10-23-2015 10:32 AM
Noveske
02-14-2009 10:20 PM
Noveske
02-14-2009 01:53 PM
dakotajeep
03-07-2008 10:27 AM
Quick Reply: Replacing front tank tube assembly.
