Replacing front tank tube assembly. - Ford Truck Enthusiasts Forums
Old 06-23-2014, 01:16 PM
Groundpounder0331 Groundpounder0331 is offline
Groundpounder0331 is starting off with a positive reputation.
Hello. I disconnected my front tank supply and return fuel lines from the sending unit, and broke the connection where the supply line connects to the sender. OEM parts from the Dealer are about $188 for a new tube assembly. Anyone know a cheaper venue for this part? Part number is F5TZ-9H334-D. Thanks in advance.
Old 06-23-2014, 07:38 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
You can just cut it off and use a rubber hose with clamps. Double or triple clamps each side.
Old 06-23-2014, 08:50 PM
madpogue madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
Did you break the pickup, or the sender? The sender is attached to the pickup, but they're not "connected", per se.
Old 06-23-2014, 10:08 PM
I thought he meant the quick disconnect line broke that attaches to the sender lines on the outside of the tank.
Old 06-24-2014, 12:51 AM
The sender is electrical. This is what's confusing.
Old 06-24-2014, 12:17 PM
Just to clarify... the quick disconnect clip located inside the hose where it connects to the top of the fuel tank (sending unit?) became disfigured when I removed it. I didn't use the fuel line disconnect tool correctly. I thought the entire hose had to be replaced. After bad info from the dealership saying I had to replace both hoses, my local mechanic told me you can replace the clips with NAPA aftermarket parts. Picked some up last night for a few bucks, problem solved. I almost spent $200 buying two new hoses.... My mechanic saved me some serious cash.
Old 06-24-2014, 02:55 PM
That's good to know!
Need a little help eliminating rear tank iwals 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 03-30-2016 10:51 AM
2003 Expedition 5.4l fuel leaking front of tank dstrahm 1997-2006 Expedition & Navigator 8 02-24-2015 01:00 PM
1995 Ford F150, 4WD, 5.0L, Supply & Return Tank Fuel Lines OFLM 1987 - 1996 F150 & Larger F-Series Trucks 0 07-13-2014 01:33 PM
99 f250 7.3 powerstroke fuel leak Fordx4jake 1999 - 2003 7.3L Power Stroke Diesel 8 06-11-2014 07:43 PM
Not Blowing Warm Air howlincold Explorer, Sport Trac, Mountaineer & Aviator 4 12-16-2008 09:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
