Replacing front tank tube assembly.
Hello. I disconnected my front tank supply and return fuel lines from the sending unit, and broke the connection where the supply line connects to the sender. OEM parts from the Dealer are about $188 for a new tube assembly. Anyone know a cheaper venue for this part? Part number is F5TZ-9H334-D. Thanks in advance.
Just to clarify... the quick disconnect clip located inside the hose where it connects to the top of the fuel tank (sending unit?) became disfigured when I removed it. I didn't use the fuel line disconnect tool correctly. I thought the entire hose had to be replaced. After bad info from the dealership saying I had to replace both hoses, my local mechanic told me you can replace the clips with NAPA aftermarket parts. Picked some up last night for a few bucks, problem solved. I almost spent $200 buying two new hoses.... My mechanic saved me some serious cash.
paddler
02-27-2017 10:59 AM
annaleigh
10-23-2015 10:32 AM
Noveske
02-14-2009 01:53 PM
