Need help - Ford Truck Enthusiasts Forums
Need help
Old 06-23-2014, 01:30 PM
Brent Chima Brent Chima is offline
Brent Chima is starting off with a positive reputation.
Need help
Ok i have an 89 ford ranger 2.9 liter v6
It has 72,000 original miles
My problem is i was driving back from the store when i smelt something burning got home noticed there was oil all over the undercarriage i have no idea to what or where to look for my problem also as i was pulling in the truck began to tick im assuming thats from the motor not having enough lubrication please ill take anything you can offer knowledge wise
Old 06-23-2014, 06:21 PM
xlt4wd90's Avatar
xlt4wd90 xlt4wd90 is offline
xlt4wd90 is gaining momentum as a positive member of FTE.
Yes, the engine will tick (clack) loudly without oil. You should not be driving it that way, or you will destroy the engine.
Did you lose an oil drain plug? That would be on the bottom of the oil pan.
Did you drive over something that punctured the oil pan? Again look closely at the pan.
Did the "Check Engine" light come on when this happened?
Also, might I suggest punctuations? Your run-on sentences are kind of hard to read.
Old 06-23-2014, 07:13 PM
I will check for the oil drain plug.
And as far as i know i didnt run anything over.
My check engine light did not turn on however.
I appreciate the suggestions and sorry about the run on sentences.
If i find something out of the ordinary tonight i will let you know
Old 06-24-2014, 11:34 AM
So last night i got under the ranger, checked the pan and there wasn't a single mark on it. Checked the drain plug it was in there nice and tight. Everything looked fine. Getting frustrated i went and bought oil filled it and there was no leak. So now i know it needs to be under pressure for it to leak. So i started the truck it started totally fine looked under neath to find that what i believe is the oil sending unit spewing oil everywhere.
Old 06-24-2014, 07:09 PM
xlt4wd90's Avatar
I've seen that happen before. It's worked fine for all its life and one day it just decides to let go. Glad you found it, and it was a simple problem to solve. Hopefully you did not damage your engine too much while it was leaking.
Old 06-28-2014, 01:20 AM
Beanscoot Beanscoot is offline
Beanscoot is gaining momentum as a positive member of FTE.Beanscoot is gaining momentum as a positive member of FTE.
Oil leak
There's a pretty good chance that there will be no engine damage. Last summer my Escort started to lose oil pressure, as indicated by the warning light coming on. I drove it for a couple days until I investigated whether it was a faulty gauge or true oil pressure loss.
I found there was virtually no oil pressure nor flow at higher rpm, and then found the oil pickup screen clogged. After correcting the problems, the car's been running great ever since.
Problem with fuel Mikey bist 1999 to 2016 Super Duty 0 12-16-2015 04:27 PM
problem with autozone discount code? cjben General NON-Automotive Conversation 0 06-30-2015 05:21 PM
Duel gas tank problems makattack 1987 - 1996 F150 & Larger F-Series Trucks 6 11-14-2014 12:47 PM
Air filter full of oil tasboj 1967 - 1972 F-100 & Larger F-Series Trucks 28 10-27-2014 09:38 AM
2009 Ford F 150 cbrantley1 2009 - 2014 F150 2 08-05-2014 12:23 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
