Coolant filters
#47
I installed a bypass filter a few years ago because I didn't want to change out a perfectly good Ford waterpump just to get the built-in filter of the International.
Also, it was easier to plumb than the changes necessary to install the International.
Also, if I need a pump on the road, I'm presuming it would be easier to find a Ford than the International, since the Ford is in all the books for my year-and-model compared to a converted hybrid.
All this is just the stream-of-consciousness I experienced those few years ago.
#48
#49
Tayln has a point about how expensive it is.
Basically you need brass fittings, the filter base, the filter, some hoses, clamps, and a piece of metal to mount it on.
I was able to get a hold of a Diesel Site unused kit from a forum member who opted to go the IH water pump direction and bought from him for like $75 lol.
But still $100 isn't bad considering parts would be $40 or so(all depends on how saavy of a shopper you are).
It also worked well and was manufactured well. The minute I took mine off I had 3 friends asking about it. Sold it easily! LOL
#50
I understand your comfort in knowing you could find a OEM pump if you were ever in a tight spot, but water pumps don't catastropically fail all that often (at least not with proper cooling maintenance).
I am pretty sure my pump that I replaced was factory, and it never really 'failed' it was still keeping my truck cooled its just the bearing/seal or whatever was bad and it was weeping coolant CONSTANTLY!
#51
#52
#54
I did! Thanks. I like the isolation ball valves! I was thinking about doing a differential psi gauge set up as well.. In not doing a WP until I have to but more than likely will be doing a bypass this time home. Question, when you refilled your system, did you use that Fleetguard everyone talks about?
#55
#56
So I have a question, if you have your charge where its suppose to be, will adding a charged filter over charge the system? I got a Carquest 89071 (exact same as a NAPA 4071) or is it the same principal as take it as it needs it? Or do you need to wait untill it needs a charge before you can add a charged filter?
Basically what I'm asking is, its designed to maintain the charge not add to it correct? So in theory changing to a charged filter should get it to/keep it where its suppose to be. I hope that made sense...
#57
I just looked at Penray and they state their filters contain a synthetic membrane that allows SCA's to be released from it based upon corrosive degree of the coolant. They also state that they are to be used with pre charged.
I also looked at Donaldson and they appear to have several types of SCA filters:
Pre-Charge which takes care of initial SCA concentration plus maintenance levels, to filter change.
Standard Charge which maintains SCAS from a good base level, to filter change.
Blank/no charge.
Donaldson Endurance Plus which releases chemicals over a period of time, maintaining good levels (maybe same as standard charge?)
Guess I didn't realize there was this much to a coolant filter system.
What happens if the coolant system is overcharged with additives?
A: Over charging or over concentrating a coolant system with additives will result in the formation of solids. These solids will form deposits that drop out and clog passage ways in the system preventing proper heat transfer. These solids are also very abrasive and will permanently damage surfaces they come in contact with. If a coolant filter is in use, it will be quickly plugged up.
#58
#60
Glenn, I see no problem with what you did either. Should be just fine. I haven't tested mine since I put the charged coolant in, I don't have the right test strips for it.
