maintenance. - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
maintenance.
Old 06-23-2014, 06:12 AM
brandon.edwards brandon.edwards is offline
brandon.edwards is starting off with a positive reputation.
maintenance.
Coming up on 3K on my 15' F350 and was wondering when you guys did your first oil change and are you just using Motorcraft oil, or running any synthetics that you guys like? Ive always done gas motors at 3K miles, but coming from my 6.0 its a little change of pace than what i was used to.
Old 06-23-2014, 07:30 AM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold
I'm not using synthetic. Some good feedback in this thread:
http://www.ford-trucks.com/forums/12...il-change.html
Old 06-23-2014, 08:57 AM
rvpuller's Avatar
rvpuller rvpuller is online now
rvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud of
I changed the first time at 3K because the 1st one was free (not really) at the dealership and we were leaving for the winter. The second one was done at a dealership in Texas after another 5K and I'm thinking that every 5K is what I'm going to use for now. For what it cost at the dealerships and the pain it is on the road to change it I'm going for the first time in my life let them do it with their Motocraft blend from now on. Next change will be somewhere on the east coast this fall.
Denny
Old 06-23-2014, 09:02 PM
BigMix's Avatar
BigMix BigMix is offline
BigMix is starting off with a positive reputation.
Definitely at 3K. There lots of metal pieces floating around and are filling up your filter. The dealership offered a free first oil change with Motorcraft Synblend. At 8K I switched to Mobil 1. I have used it in all of my vehicles and have had good results.
Old 06-23-2014, 09:04 PM
saratoga2011's Avatar
saratoga2011 saratoga2011 is offline
saratoga2011 is starting off with a positive reputation.
Did the first one at 1500 and then at 7500... have been sticking to 7500 mile changes as recommended in the book since. I've used MC 5W20 for all changes except one.
Just did it at 22,000 over the weekend because I have a trip coming up. These trucks are super easy to work on in case you're considering whether to do it yourself or not.
Old 06-24-2014, 08:34 PM
LCT LCT is offline
LCT is starting off with a positive reputation.
Every 6 mths or 7500 miles whichever comes first, Amsoil synthetics followed with a bottle of Amsoil fuel injector treatment/cleaner. Been doing this for years on my other vehicles and the 6.2 is no different. Truck runs great and smooth.
Old 06-24-2014, 09:28 PM
22rimfire 22rimfire is offline
22rimfire is gaining momentum as a positive member of FTE.22rimfire is gaining momentum as a positive member of FTE.
Changed it at 2,000 and then at 5,000. I do every 5,000 in mine as I did in my previous truck. I use the MC syn blend and MC filter as well. Tomorrow will be exactly one year since I bought mine, and I only have 5,600 on it, so I'll probably start changing it at the 6 month mark if I haven't put the 5,000 on it. As was mentioned, it's very easy to do yourself.
Old 06-28-2014, 04:43 PM
lawnspecialties lawnspecialties is offline
lawnspecialties is starting off with a positive reputation.
Every 7500 miles. Mobil 1 0W-30.
I don't mind using a higher quality oil. But I'm tired of doing the changes every 3K-4K.
Old 06-29-2014, 08:57 AM
JohnnyThunder JohnnyThunder is offline
JohnnyThunder is starting off with a positive reputation.
Mine is changed when the dealer says to on their sticker. I always go to the dealer as they are cheaper than any of the fast lube places and check more (may not be the case everywhere though) and I just put in what they recommend. My truck has abt 72,000 miles on it now.
oil in intercooler tubes on a 240k mile engine tjc transport 6.0L Power Stroke Diesel 4 02-19-2016 10:53 AM
Oil change frequency observation MDSuperDuty 1999 to 2016 Super Duty 51 02-01-2016 01:54 PM
Oil change frequency cracked block Ranger & B-Series 9 03-10-2015 02:39 AM
F.Filter & Oil Change Intervals ??...Not as easy as u think King-bRanch 6.0L Power Stroke Diesel 22 07-28-2013 12:59 PM
Do you change your own oil? Kbota 6.7L Power Stroke Diesel 16 07-24-2012 12:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
