Move the Oil Pressure Sender Location? - Ford Truck Enthusiasts Forums
Old 06-22-2014, 06:18 PM
sseebart sseebart is offline
sseebart is starting off with a positive reputation.
I'm working on a 62 292. Someone added a mechanical oil pressure gauge in the past and now the plastic tubing is leaking. I'm looking to replace the gauge with an electric unit, but doubt I can get an electrical sender to fit:
Is there any chance I can tap into another location for the sender? Would one of these two locations, just south of the fuel pump work?
Thanks, in advance.
~Steve
Old 06-22-2014, 07:52 PM
f5fordgirl f5fordgirl is offline
f5fordgirl is starting off with a positive reputation.
I think orig the unit was in the most forward location.
Old 06-23-2014, 12:48 AM
Y-Blockhead's Avatar
Y-Blockhead Y-Blockhead is offline
Y-Blockhead is starting off with a positive reputation.
Any of those will work, they all tap into the main oil gallery that runs down that side of the engine.
Except the plug just below the freeze plug of course. That's the block water drain.
Old 06-23-2014, 09:55 AM
bjmayberry2's Avatar
bjmayberry2 bjmayberry2 is online now
bjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud of
You can "T" fitting the original location and install the electric and mechanical gauges!
Old 06-23-2014, 10:51 AM
Thanks. I'll see if I can get that one to turn. Would like to avoid t-fittings and other adapters--fewer opportunities for leaks!
~Steve
Old 06-23-2014, 10:56 AM
I just used pipe thread sealer. No leaks so far
F-100 project Jerry Husky 1967 - 1972 F-100 & Larger F-Series Trucks 19 05-05-2016 09:22 PM
Another Gauge Install eakermeld 1987 - 1996 F150 & Larger F-Series Trucks 9 02-03-2015 07:47 AM
A repair, and, of course, another repair needed- Help a girl out? TheDawnof68 1967 - 1972 F-100 & Larger F-Series Trucks 10 10-01-2014 06:06 AM
My First repair job TheDawnof68 1967 - 1972 F-100 & Larger F-Series Trucks 7 09-29-2014 08:39 PM
1994 F350 Lifted 4X4 Chrisrehpot Vehicles for Sale 1 09-24-2014 07:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
