MAF questions - Ford Truck Enthusiasts Forums
MAF questions
Old 06-22-2014, 03:31 PM
rickdavis81 rickdavis81 is offline
rickdavis81 is starting off with a positive reputation.
MAF questions
I've been reading and reading on MAF swaps for my 97 460. To make sure I have this right, I can use the MAF and ecm out of an early 90's 5.0 mustang cobra that used 24lb injectors. Hook that ecm to my harness after repinning for the injectors and adding in the MAF wire harness. And I should be good to go? I'll probably build my intake tube or buy the k&n kit unless I can find one easy. Are there only certain years of stangs I can use the parts from? Sorry I know this has been gone over countless times just want to make sure I got it right.
Old 06-22-2014, 04:35 PM
F350 1990's Avatar
F350 1990 F350 1990 is offline
F350 1990 is starting off with a positive reputation.
Quote:
Yes I think you're ok ---the 80mm MAF is actually cal'd to the ECM (not the injectors) so it's good you're bringing it to the party too............
Old 06-22-2014, 05:28 PM
Ok, thanks. They're are some ecm/maf combos on ebay for around $250. Didn't seem like to bad a price.
Old 06-22-2014, 08:54 PM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
You have to also add wires for sequential injection(9 wires), SD is batch fired and only has 3 wires.
Old 06-22-2014, 10:41 PM
Is there somewhere to get pins to add to the ecm plug or do I have to buy a harness?
Old 06-22-2014, 11:04 PM
macskill macskill is offline
macskill is starting off with a positive reputation.
if you have an automatic you will need a tranny controller also
Old 06-23-2014, 02:36 PM
She's got a ZF5
Old 06-23-2014, 02:48 PM
Crewcabber's Avatar
Crewcabber Crewcabber is offline
Crewcabber is gaining momentum as a positive member of FTE.
Subscribed. Interested to see if the swap to maf is worth the hassle. As far as the tranny controller where would you find one.
Old 06-23-2014, 03:37 PM
Shadow944795's Avatar
Shadow944795 Shadow944795 is offline
Shadow944795 is starting off with a positive reputation.
I'm wondering how this would go as well with a 5.0 computer. be kinda cool if you ask me.
Old 06-23-2014, 04:55 PM
cbakker's Avatar
cbakker cbakker is offline
cbakker is starting off with a positive reputation.
It would work as long as you mod your harness and re pin your connector. I haven't looked for awhile but there used to be pinouts on oldfuelinjection.com, but i'm not sure if the site is still up. There are many good sources such as moates.net, and eectuning.org where guys can point you in the right direction.
I'm in the middle of my swap right now with my 460/E4OD, with 3.55's. I have been watching it sit due to my just getting married yesterday, and having no time to work on it!
I went with a kit from Fiveology racing which included an EEC-IV out of a 95 F-150(or bronco) with a MAF 5.0, and an 80mm meter with a harness that is already pinned for the connector. I'm also going to run a Moates quarterhorse, and BE/EA combo for tuning. With the f-series E4OD PCM, I don't have to worry about running a transmission controller. I got my intake from a JY MAF 5.0. I took only the top half of the air box, assuming it would fit on my bottom half but was mistaken, so I have yet to return to the JY to get the other bottom half.
I plan on getting back to it soon, now that I'll have a little more time(bathroom remodel had to be first I guess.) My thread is a ways down in the BBF forum, but hopefully I'll be bringing it back to the top soon.
MAF Conversion - O2 sensor wiring? Glaser67 1987 - 1996 F150 & Larger F-Series Trucks 6 09-08-2016 10:22 AM
460 mass air conversion rdbcole1956 1987 - 1996 F150 & Larger F-Series Trucks 12 09-02-2014 02:58 PM
460 Maf swap eec-iv vs eec-v? nebechanezer 1987 - 1996 F150 & Larger F-Series Trucks 11 02-12-2013 08:37 PM
Aem ecu experts? bank to bank to sequential possible? Duramaxfanatic1 1987 - 1996 F150 & Larger F-Series Trucks 1 05-24-2011 06:04 AM
twin turbos on 5.8 using 2 probe ihi turbos?also blow through maf Duramaxfanatic1 1987 - 1996 F150 & Larger F-Series Trucks 12 05-16-2011 09:33 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
