MII power steering problem
Old 06-22-2014, 12:14 PM
B/B ford's Avatar
B/B ford
B/B ford is offline
Clean & Classy
While parking yesterday my steering wheel started oscillating back a forth in small increments, becoming hard to turn. and when I let go and stopped moving, it continued for a short time. When I got out on the road on the way home it felt really good. I thought maybe it had burped an air bubble or something, but when I got home and was parking again it started doing the same thing.
I jacked the front end up and went through the recommended air bleeding procedure but it didn't help.
Has anybody else encountered this problem?
Old 06-22-2014, 12:24 PM
Project-55's Avatar
Project-55
Project-55 is offline
If you are using mismatched parts like a ford rack and chevy pump, you might have a pressure mismatch too. Right off hand I can't think of anything else that would cause the un commanded cycling.
They do sell pressure relief valves to match different pump / rack combinations.
Good luck and keep us informed as the final cause.
Old 06-22-2014, 04:22 PM
B/B ford's Avatar
B/B ford
B/B ford is offline
Clean & Classy
back to the top
Old 06-23-2014, 01:11 PM
B/B ford's Avatar
B/B ford
B/B ford is offline
Clean & Classy
These are not mis-matched parts.
It is a system designed by F.R. With a GenII power steering pump matched to their rack and pinion.
I sent them an E-mail and am still waiting for a reply.
I was just hoping that someone on here had already encountered and solved this problem.
Old 06-23-2014, 01:40 PM
AXracer's Avatar
AXracer
AXracer is offline
Sounds to me like a sticking pressure relief valve in the rack (but possibly in the pump)
Old 07-24-2014, 09:36 PM
B/B ford's Avatar
B/B ford
B/B ford is offline
Clean & Classy
This is a follow up on my steering problem. I decided the cheapest way for me to trouble shoot whether it was the pump or the rack, was to replace the pump with a rebuilt one. I tried ordering on from Oreilly's for $45 but it wouldn't match my fittings. I returned it and found a F.R. pump. A variable pressure low flow from Jegs just like the one I have, for $193. Just put it in today and Voila! power steering has never worked this good before. I glad it wasn't the rack and pinion.
Old 07-25-2014, 08:30 PM
Baldy66's Avatar
Baldy66
Baldy66 is offline
B/B Ford
Do you have the part number?
Old 07-25-2014, 11:37 PM
Rimrock F1's Avatar
Rimrock F1
Rimrock F1 is offline
Thank you for the update. Glad you got it solved.
Old 07-26-2014, 01:24 PM
B/B ford's Avatar
B/B ford
B/B ford is offline
Clean & Classy
Originally Posted by Baldy66
B/B Ford
Yes, The part Nr. is, Flaming River #898-FR1570 from Jegs $193.99 Free shipping
Old 07-26-2014, 07:46 PM
Baldy66's Avatar
Baldy66
Baldy66 is offline
Thanks!!!!
tygerrrr
08-09-2011 03:37 PM
tlb
03-20-2011 09:09 AM
justanother1
07-25-2005 02:49 PM
raiderman
2004 - 2008 F150
10-10-2004 08:53 AM
Quick Reply: MII power steering problem
