Ignition ground wire ?? problem
hey guys... need some help.
There is a small black wire going to the outer edge of the ignition and it has a small black plastic retainer clip that holds it in place. It make contact with the ignition tumbler. Problem is the plastic has broken and the door chime wont stop, plus it is draining my battery somehow. I tried to glue the plastic piece to keep it in place but that is when the battery started to drain all the way down. This wire (which must be a ground wire) comes out of a small wire harness (it has a yellow outer cover) that goes through the bottom of the steering column and also runs to the cruise control in the steering wheel. It then connects under the dash with a standard male/female wire harness connector.
I am looking to replace this yellow wire harness... Does anyone know a part number?
Thanks,
Andy
Thanks,
Andy
Thanks,
Andy
Thanks,
Andy
The following 2 users liked this post by udsuth78:
Andy
The following users liked this post:
charbaugh
1999 to 2016 Super Duty
11-11-2015 07:30 PM
big boy toys f250
09-04-2014 06:11 PM
Robber80
04-22-2007 05:33 PM
