Gas milage issues - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Gas milage issues
Old 06-22-2014, 12:19 PM
Jonesy1981 Jonesy1981 is offline
Jonesy1981 is starting off with a positive reputation.
Gas milage issues
I recently purchased a1985 Ford Bronco with the 300 I6 and Np 435. I was getting about 18-23 mpg at first. Now I get about 7-9 mpg. The only thing I changed was the tires. At first I had 235/75/15. Now I have 31x10.50/15. The tires are about a 1/2" taller than the factory tires. I have never been much on Ford but I fell for this one . Would the tires change the mpg that much? Is there anything I can do to get better gas mileage that won't cost over a few hundred dollars. I bought the truck for $700 and have invested $4000 in small repairs. Windshield, clutch, tires, wheel bearings, fluids, etc. Any info will be greatly appreciated. Thanks for your time.
Old 06-23-2014, 07:12 PM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
235 is 9.25 inches
6.9 inches high, 15 inch wheel
15+14=29 inches diameter
So you went from 29 inches to 31 in the diameter
and you went from 9.25 inches wide to 10.5 inches wide
and your new tires might weigh significantly more than your old ones.
29 pie=91 inches, 63360/91=696 revolutions to go 1 mile
31 pie=97 inches, 63360/97=653 revolutions to go 1 mile
odometer reads 1 mile at 696 revolutions
Odometer with new tires reads 1 mile but actual mileage is
6 percent more
Old 06-23-2014, 11:33 PM
Quote:
Originally Posted by g_k50 View Post
235 is 9.25 inches
6 percent more
Thanks for the info. So it's the tires that are screwing my mpg up. If I add a 2 barrel carburetor would that give me better mpg. I like the truck alot and I finally have a dependable vehicle but the mpg's are killing my wallet especially when pulling anything. Another thing I noticed was I can smell gas when walking around and sometimes driving the truck but can't find a leak anywhere. Any ideas. Thanks again for the info. It's greatly appreciated.
Old 06-24-2014, 03:14 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
what gear ratio do you have? I bet its 3.08's in which case you could probably swap over a later year bronco front/rear diff to get 3.55's and see a great boost in performance. anytime you increase the tire size though your going to loose mpg not just due to tire size but also the vehicle being taller.
Old 06-26-2014, 09:53 PM
Quote:
Thanks for responding. How would I tell what gears are in the rear end and front end? Would I have to change the front end gears also? I was thinking about rebuilding the carburetor. It looks a little wet at times. It maybe leaking idk? I have been told to get 2 Ford 9" rear ends for the front and the back. That's alot of work and I'm in the whole now I will never get the money I have in it....lol. But I really like the truck. Just want better gas mileage. I may just go back to stock tires. They just don't give it that mean look. Idk what to do. Thanks for the info. It's very useful.
Old 06-27-2014, 05:59 AM
gatorfor88's Avatar
gatorfor88 gatorfor88 is offline
gatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputation
I dont think you can attribute just the tire change to that drastic a drop in mpg. You say you smell fuel and carb looks wet sometimes. I am betting you have more problems than tire size.
Old 06-27-2014, 02:40 PM
start researching
Old 06-29-2014, 11:55 PM
start researching
Just bought a 2 barrel carburetor. What do I need to do to swap it out. I have read to use efi manifolds. What's the difference in the manifold that I already have. I was just planning on using a flat plate 2 to 1 adapter. The carburetor is a 9T motor craft. I'm hoping I can just swap it with no problems. Any suggestions are greatly appreciated. Thanks for your time.
Old 07-02-2014, 01:32 AM
dan240 dan240 is offline
dan240 is starting off with a positive reputation.
I have an 83 Bronco, 6 cyl, NP435, 3.55 gears (stock) and 31" tires. I'm still getting in the high teens on the freeway.
You have something wrong with your truck and its not the tires. Too large a drop in mileage to be from tires alone.
If your truck is not running pig rich you must have a fuel leak somewhere. Brakes dragging?
Old 07-02-2014, 09:55 PM
The brakes do clang when applied. I let my wife drive it and the park brake doesn't work anymore. It feels a little weird like a thump under the seat from time to time. Could the brakes be stuck? I'm gonna check them out and get back with the outcome. Dang why didn't I think of that 😒...Thanks for the info.
Old 07-27-2014, 08:45 AM
benshere benshere is offline
benshere is starting off with a positive reputation.
power valve
If you dont see a large leak on the exterior, check manifold vacuum for base gasket leak which may cause power valve to stay open. Check power valve anyway, depending upon age of carbs, replace power valves anyway.
Old 07-27-2014, 09:22 AM
Quote:
Thanks for the advice. I have a 1648 alumacraft boat. I pulled it to the lake for the first time the other day. The lake is in the mountains of Henry county. The hills are terrible, by the time I got to the top I was in first gear. Do you think a 2 or 4 barrel carb would help out on the pulling power.
Bad MPG with 5.4 Grappler150 Modular V8 (4.6L, 5.4L) 5 01-27-2014 08:55 AM
12" lift 39.5" tires 4.56 gears = 6.6 MPG!?! Mo111222 Excursion - King of SUVs 29 07-03-2013 04:23 PM
Mileage ROI: Ratio change, tires or hedders? DrainBramage 1973 - 1979 F-100 & Larger F-Series Trucks 3 08-03-2011 02:06 PM
Tire Size ruining MPG??? Mdennis0_8 1999 - 2003 7.3L Power Stroke Diesel 31 04-06-2011 04:54 PM
Bigger Tires = Better or worse MPG??? Ak Ford Man 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 20 02-04-2011 01:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
