Opinion on truck
#151
I have the 7.3 injector plug and I am applying 12 volts to it. I have not replaced the Stc fitting my self. I would assume it would have been done previously but that does not mean it's not bad. Now as I have dug further into it there is what sounds like an air leak back there so I pulled the cover and I have a very strong hissing sound which I am assuming is my leak. I am told there is only two things that can leak. The Stc fitting and the o rings under the hpop. Going to go investigate it further.
#152
#156
<p>
</p>
<p>you may try and get a better look at the fitting it as I believe they made a metal plate as a way to keep the original STC fitting from coming apart, is the alignment plate metal or plastic?The revised STC fitting only requires the alignment tool to set the alignment when installing the fitting into the pump and is then discarded before the pump is reinstalled. </p>
#157
#158
<p>
</p>
<p>I am thinking so, but watch that video and see if its possible to see the STC fitting under that plate just to be sure. There are stark differences between the two styles of fittings so it should be easy enough to tell. p>
#159
#160
Found my leak, there's a hole on the firewall side of the hpop that must have had a machined plug in it that is no longer there. After I changed the Stc out to the new style fitting I re pressurized the system and could still here the leak. After feeling around I found it. Well I guess back to the parts store in the morning. This trip is gonna hurt though!
#162
Just to be sure, does your HPOP look like this one?
This is the update STC fitting. No plastic collar around the middle of the round section.
Wish I had a picture of the back of this pump to see where the leak is . The earlier style pump has a hole with a steel ball in it that can get popped out when the pump fails.
Here is good thread on the subject. Don't miss page 2.
https://www.ford-trucks.com/forums/1...firmation.html
#163
I will sit down and read your link in a bit. My pump does look just like the one pictured. If your looking at the backside of the pump (where the gear is) the hole the air is coming out is a most in the center of the pump behind the gear. There is another plug to the left and slightly above it. I had to rotate the pump.and look threw the gear just to look into the hole.
#164
