Oil pressure/Engine temp sending - Ford Truck Enthusiasts Forums
Old 06-22-2014, 07:41 AM
benbuilder's Avatar
benbuilder benbuilder is online now
benbuilder is starting off with a positive reputation.
I have a 77 f100 302 stepside. that I bought in many pieces. Wiring harness was in the cab. I used the forum and my daughters 75 f100 as a guide. It was not running until yesterday. Very proud of myself I might add. Big step for me not for most of you guys though. The PO has installed an Edelbrock Performer 298 manifold and an Edelbrock Carb.
I have two wires on the engine that have not found a home.
I believe the red with a white stripe is for the engine temp sending unit. My first question or observation is that the manifold had a wire coming out of where the sending unit should be. This wire runs to the firewall and connects to nothing. Why would someone use a different wire and sending unit? Are the threads different in the Edelbrock? Should I splice them together and see what the gauges read (when I install the gauges) then rewire using the correct one?
The tan with red stripe I think goes to the oil pressure sending unit. The sending unit is not there, In its place is a small plastic hose that runs to nowhere. I did notice that it pumped out oil for the brief 2 seconds I had the engine running until I shut it down because I did not have a radiator installed yet. Where were they intending to go with this? There were no aftermarket gauges in the truck. I see that LMC sells two different switches. One for use with a guage and for use without. How would one know if the pressure is low without a gauge? Should I pick up a sending unit and install it using the original wire?
Thanks for the help.
Old 06-22-2014, 08:27 AM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is online now
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
The "plastic line" is for an aftermarket mechanical gauge. The factory set up was either an idiot light or an electric gauge. Which sender you use depends on the instrument cluster you have. If you have a light, the sender can just screw into the port on the block. If you have a gauge, the sender is much larger and needs an extension to move the sender out and clear the oil filter.
As for the wiring, I would get the correct temperature sending unit and use the factory harness, the wire color is white w/ red trace for the oil pressure sender and red w/ white trace for coolant temp.
There is a separate wiring harness for the gauges and ignition called "engine gauge feed harness" it plugs into the main harness behind the engine at the firewall.
Old 06-23-2014, 04:38 AM
benbuilder's Avatar
Thank You very much Mike. I am enjoying reading your build thread.
Old 06-23-2014, 07:58 AM
mikeo0o0o0's Avatar
Quote:
Thanks, haven't had a lot of time to work on the ol' girl lately .
1968 f100 Gauges Issues 68Rookie 1967 - 1972 F-100 & Larger F-Series Trucks 21 10-27-2016 03:57 PM
Oil pressure sending unit Rocketattack Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 04-25-2016 10:00 PM
electrical plugs for the engine temp. sending unit and the oil pressure unit? Help!!!!!!! 1965F100(3onthetree) 1961 - 1966 F-100 & Larger F-Series Trucks 11 03-29-2012 12:23 PM
aftermarket oil pressure gauge problem 88grandmarquis 1987 - 1996 F150 & Larger F-Series Trucks 19 07-12-2011 10:58 PM
New Gauges Installed - Oil Pressure, Oil Temp, & Water Temp jtharvey 1999 - 2003 7.3L Power Stroke Diesel 16 11-14-2006 01:03 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
