Transmission's - Ford Truck Enthusiasts Forums
Transmission's
Old 06-22-2014, 05:56 AM
blue oval outlaw blue oval outlaw is offline
blue oval outlaw is starting off with a positive reputation.
Transmission's
Hey guys, new here. I own several 9th generation F series. Currently just bought '94 1/2 F-250 with 7.3 turbo. My question is will a transmission out of an '01 Stroker bolt up to my '94? If not, are bellhouseing abel to swap ? Or just get new TC and rebuild kit and be done? Thanks, any information will be appreciated
Old 06-22-2014, 07:51 AM
Motroo Motroo is offline
Motroo is starting off with a positive reputation.
can't wait for the answer to this. I just bought a 95 van and just now came across a guy with a wrecked 2002 f250 with a recently rebuilt e40d. not sure if i want to spend the money or not as I am going to put a 4x4 conversion under it next spring.
Old 06-22-2014, 08:07 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Quote:
The trans will bolt up, but the converters are different, and there are some other differences, too.
Your converter has four studs. The newer converter has six. I think you can swap the flex plates so that it will bolt up.
I think there are some differences in the wiring to the solenoid body. I don't have wiring diagrams to be able to check, you'll want to look into this.
There is an orifice in the pump body that controls the torque converter lockup speed. The 4R100 in the 2001 has a 0.250" hole, your trans has about a 0.030" orifice. If you leave the big hole there when the converter locks it will SLAM on. It isn't pleasant.
Quote:
No, you did not. The last year the E4OD was produced was 1998. The 2002 has a 4R100. See above.
Old 06-22-2014, 08:24 AM
farmert farmert is online now
farmert has a good reputation on FTE.farmert has a good reputation on FTE.farmert has a good reputation on FTE.
94.5 with an auto would be an IDI, unless someone put an auto into it. The 94.5 trucks left the factory with ZF5 manual trannys only. If you have the IDI, the flex plate bolt pattern for the Stroke is different.
Old 06-22-2014, 09:32 AM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
What is the 8th digit of the VIN ?
Old 06-22-2014, 09:58 AM
ok, my bad, it was a 2001, but says e40d. guess i won't be getting that one.
What 302 can I put in my 94 f150? Jake Summers Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 01-04-2016 09:37 PM
Leveling kit for 94 XLT F150? XLT94 1987 - 1996 F150 & Larger F-Series Trucks 8 07-08-2014 12:37 PM
94 F150 e4od transmission problem CCope94 1987 - 1996 F150 & Larger F-Series Trucks 11 07-26-2012 08:54 AM
need info on my 94 f150 transmission big boy toys f250 1987 - 1996 F150 & Larger F-Series Trucks 7 01-15-2012 12:11 PM
5 speed manual transmission michbol Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 10-21-2010 07:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
