Isspro EV2 fuel pressure gauge - Ford Truck Enthusiasts Forums
Old 06-22-2014, 01:00 AM
xaviar's Avatar
xaviar xaviar is offline
xaviar is gaining momentum as a positive member of FTE.
Finally got my gauge functionable. I have the 100psi EV2. Gauge works good but bounced between 60 & 70 psi. Its mounted to the test port with 3 brass fittings connectors.
Thx.
Old 06-22-2014, 08:22 AM
Jmoen7 Jmoen7 is offline
Jmoen7 is starting off with a positive reputation.
How do you have the sending unit mounted? Straight to the fuel filter housing? That's sure to kill the sender in a month, if it hasn't already done damage. Engine will rattle it around creating bouncing and after a while, it won't bounce anymore and just read max i experienced this with glow shift.
Should have a relocation cable, and be mounted away from engine vibration for maximum life.
If the above, is already done, did you inspect your fuel test port for debris before installing? Bottom of fuel housing clean? Blue spring mod done?
The numbers are good, bouncing is bad.
Old 06-22-2014, 10:58 PM
xaviar's Avatar
I have my sending unit mounted like this 2005 Ford F250 4x2 - Fuel pressure gauge There are all kind of sensors mounted directly on this engine and felt this shouldn't make a difference for this one either. I got roughly 5 dollars in these adapters. Where as it's 50.00 to 60.00 bucks from different vendors plus shipping!!! Im going to call Isspro tomorrow. Did some searching online and there might be an upgraded sender.
Fuel Pressure Gauge Recomendation TooManyToys. 6.0L Power Stroke Diesel 2 07-15-2015 07:05 AM
ISSO PRO EV2 FP GA. Is this normal 250 STROKER 1999 - 2003 7.3L Power Stroke Diesel 6 10-01-2014 01:09 PM
ISSPRO EV2 fuel pressure gauge - programming warning light question white Buffalo 1999 - 2003 7.3L Power Stroke Diesel 8 03-06-2014 12:02 AM
ISSPRO EV`s vs. Performax Josh88Ford 1999 - 2003 7.3L Power Stroke Diesel 7 02-21-2011 01:52 AM
Isspro EV1 vs EV2 renyren 1999 - 2003 7.3L Power Stroke Diesel 11 11-20-2009 03:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
