76 F250 brownie box?
Old 06-21-2014, 08:18 PM
76er's Avatar
76er
76er is offline
Anyone have information on where to find a brownie box or some other multi-speed gear box? Looking to put one on my 76 F250 4x4 390 4spd manual.
Thank you
Old 06-21-2014, 11:39 PM
iggybob44's Avatar
iggybob44
iggybob44 is offline
Probably either CL or junkyard searching....
Old 06-22-2014, 01:41 AM
2WDfish's Avatar
2WDfish
2WDfish is offline
4X4 W/Brownie
that is gunna be a hella setup.
I hope you gotta loooong wheelbase B/C that brownis(a divorce setup) is gunna add length to your powretrain.
You would only be able to use 4x4 with the brownie in direct.
I know a guy who put in a plain ol' 3 speed Saginaw behind his primary tranny.
It gave him two underdrive gears and direct.
He put in the tallest rear end ratio he could find and it worked out great
fully loaded he used 1st in the Saginaw
around town 2nd and out on the freeway he used 3rd which equaled direct.
As for me...
I just drive slower
I got my gears setup for 65mph and installed a cheap universal cruise control.
Old 06-22-2014, 02:18 AM
Xauterus's Avatar
Xauterus
Xauterus is offline
Be easier to adapt a nv5600 six speed and transfer?
Old 06-22-2014, 10:03 AM
2WDfish's Avatar
2WDfish
2WDfish is offline
As for me...
I just drive slower
Old 06-22-2014, 10:07 AM
2WDfish's Avatar
2WDfish
2WDfish is offline
a 4 speed tranny & twin stick NP205 & brownie would make an impressive forest of shifters sticking through the floor
'prolly be tricky to set it up so none of the shifters hit each other
your tranny hump would look like swiss cheese
Old 06-22-2014, 10:23 AM
lee's Avatar
lee
lee is offline
Hi,
I recently installed a Ranger Torque Splitter on my 70 Highboy. It goes in-between your bellhousing and transmission. You have to move the 4-speed back 7 1/2 inches and only have to shorten one drive shaft. The intermidiate drive shaft (7 1/2inchs). The Ranger is a 2 speed unit,.... direct 1:1 and 27% overdrive.
The Ranger can be used in all gears, .... 4x2 or 4x4, High or Low range.
Just some more food for thought.
Old 06-22-2014, 10:43 AM
Fordworth's Avatar
Fordworth
Fordworth is offline
If someone was to figure out how to mount the Brownie between the main box and t-case it could be used for all the time. The problem is that the Brownie is about the same length as the intermediate shaft, requiring all three boxes to be coupled directly somehow. My buddy has a couple of them sitting around which has allowed me to play with the idea but apparently I'm not smart enough to figure it out.
Old 06-22-2014, 03:46 PM
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
The ranger torque splitter seems to be a good option. Advance Adapters also makes an adapter to bolt an NV4500 to your stock bell housing. Both require shortening of the center drive line only.
Old 06-22-2014, 07:44 PM
VocaTexas's Avatar
VocaTexas
VocaTexas is offline
I bookmarked this place a while back. They seem to keep a few Spicer 3 speeds in stock. Not sure how 'up' you are on these, but Spicer bought Brown-Lipe in later years and produced the boxes under their brand.
LKQ Heavy Truck - Goody's
Old 06-22-2014, 08:25 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
Old 06-23-2014, 01:44 AM
NorthwestX360's Avatar
NorthwestX360
NorthwestX360 is offline
Possibly a bad link. All I get is "runtime error."
Old 06-23-2014, 07:07 AM
mikeo0o0o0's Avatar
mikeo0o0o0
You're not missing much. All it does is take me to LKQ's search page.
See if this one will work for you. This is the page that link took me to.
http://lkqcorp.com/us/en/locations/l...toledo-oh.aspx
Old 06-23-2014, 08:37 AM
redroad's Avatar
redroad
redroad is offline
JonF250
10-11-2007 10:17 PM
magic_man77
1966 - 1977 Early Broncos
02-04-2007 05:14 PM
BillNYS
11-30-2004 02:36 PM
Tookalookaround
06-07-2002 01:18 AM
Quick Reply: 76 F250 brownie box?
