Help needed - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Help needed
Old 06-21-2014, 07:17 PM
Rutrageous Rutrageous is offline
Rutrageous is starting off with a positive reputation.
Help needed
Hey guys, new to this forum! I recently got a 95 e350 turbo diesel power stroke. The other day I drove it a few miles then parked. When I tried to start it again, the 'engine temp' light came on and it would not start. I tried a few more times then popped the hood and let it sit for a few minutes. Tried one more time and it started right up. A few days later the 'water in fuel' light came on briefly but the van started with no problems. Parked for a few minutes and noticed fluid on the ground under the front of the vehicle. Seemed to be water. I'm new to these vehicles so any help is much appreciated. Thanks!
Old 06-21-2014, 10:19 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Welcome to FTE! The "no start" could be a few different things, but first, find the coolant leak and get that fixed, then deal with the no start issue.
Old 06-21-2014, 10:37 PM
Robbieo11's Avatar
Robbieo11 Robbieo11 is offline
Robbieo11 is starting off with a positive reputation.
Is it water or is it coolant if coolant i would check hase rad waterpump thermostat housing( most likely this and the damm oring) trace the leak from the ground up
Old 06-22-2014, 12:34 AM
blageurt's Avatar
blageurt blageurt is offline
blageurt is gaining momentum as a positive member of FTE.
What is the level of the coolant in the Degauss Bottle ( to the right and behind the Drivers Side battery ) ? Also when was the last time you tested the coolant ? Do you have enough DCA in it ?
Old 06-22-2014, 02:00 PM
IDMooseMan's Avatar
IDMooseMan IDMooseMan is offline
IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.
I see you stated "fluid" rather than "coolant" in your initial post. FWIW, if you using the air conditioner before you parked, the "fluid" could be condensation and is normal.
Coolant will have a greenish tint. If the "fluid" is greenish, that would be something to investigate further, as others have previously posted.
Fuel filter issue advice Pheadrus Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 26 02-02-2016 11:39 AM
engine stalls after warming up for 10-20 minutes gary.aderhold 1999 - 2003 7.3L Power Stroke Diesel 50 12-11-2015 06:48 PM
No start devovino 1999 - 2003 7.3L Power Stroke Diesel 7 11-16-2015 05:08 PM
Can heat soak be intermittent? Maybe it's something else? EYEDEYE Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 23 09-26-2015 02:42 PM
Help! '89 F250 w/ 7.3 won't start when warm jrod76 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 10-23-2013 12:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
