Brain damage Help?
Hi,
Are you tring to remove the axle? Or ????
If you look at the wheel you can see ~6 bolts in the center of the hub that hold the axle shaft into the axle tube of each rear tire.
If you are tring to remove the brake drum, first remove the axle shaft then you will see a very large nut that has to be removed. Actually it is 2 nuts sandwitched together will a retainer. The nut is 2 5/16 if memory serves me.
take care,
take care,
we have removed the axel.
Someone before us put the spindle nuts on cross threaded and ruined them trying to find new ones.
take care,[/QUOTE]
take care,[/QUOTE]
Finally found some.
Thank you for replying. I finally found some in Phoenix. I cant believe what a pain its been to find these simple nuts..
gravdigr
07-06-2015 02:40 PM
Bobs65F600
02-25-2014 08:21 AM
RubberDuck
01-23-2010 10:59 AM
Njbmx
04-08-2003 11:50 PM
