1966 4x4
1966 4x4
Ive been a long time lurker here but decided to join today. Ive got a 1966 4x4, I bought it to bring it back to its original configuration. I think the frame is a 1960 maybe?But id like to know for sure what year the frame is so I can find a cab. The cab on there is a 66 f100 and the box I think would be correct for the frame I think. It has a Dana 24 T case, 60 rear axle and maybe 44 front axle? It also has a battery box under the passenger side of the cab. Ill try and get some pics up if I can, but any help on the year of the frame would be appreciated. Thanks
1966 F250 4WD has leaf spring front suspension, 8 lug wheels on a 6.50" bolt circle, Dana 60 rear and Dana 44 front axles, the cab has a step visible when the doors are opened and if a Styleside, uses the 1957/60 bed.
1966 F100 4WD has coil spring front suspension, 5 lug wheels on a 5.50" bolt circle, uses the same cab and Styleside bed as 1965/66 F100/250 2WD
C1TZ-8101619-A .. Battery Access Cover-located on passenger side floor pan / Obsolete
1961/65 F100/250 4WD / 1961/66 F350/1100 / 1963/69 N/NT/T500/1000 / 1966 F250 4WD / 1967/69 F800/1000.
1965/66 F100/250 2WD & 1966 F100 4WD use the same cab (no cab step), the battery is located in the engine compartment.
Does the frame have a hump at the rear axle? Or is it flat over rear axle
