"Welded to the frame" nerf bars, anyone have some? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 06-21-2014, 09:18 AM
coreyallan01's Avatar
coreyallan01 coreyallan01 is online now
coreyallan01 is gaining momentum as a positive member of FTE.coreyallan01 is gaining momentum as a positive member of FTE.
Morning, I'm thinking about ditching these body mounted running boards i have on my truck currently and going with a frame mounted set-up.. What i have is good for a dry warm climate but their just rust breeding magnets here in the Northeast and not to mention their not really my style.. Id like to go with a NFab type wheel to wheel or a solid step. Couple questions, does anyone have ether of these and if so has anyone fabbed up a frame mount for the Nfab type steps or made their own. Im trying to get an idea for where and how anybody attached the steps to the frame.. Id def make my own, id just like to see what people have done...
These aren't too bad, they list them for our trucks, a little pricey, they don't show any mounted to our body styles or mounting location...Deluxe Frame Mount Running Boards [Available Upon Order] - $875.00 : Heavy Duty Truckware | Bumpers and Accessories for Ford, Chevy, Dodge, Jeep, and Toyota Trucks
Like i said i like these wheel to wheel Nfab bars too but the mounting design is
terrible.
Manufacturers of high quality Nerf Steps, Prerunners, Harley Bars, Light Bars, Replacement Front Bumpers, Rock Rails, Rear Runners, Tire Carriers & Truck Accessories
Suggestions, advise, experience?
Old 06-21-2014, 11:34 AM
Redneckmorton's Avatar
Redneckmorton Redneckmorton is offline
Redneckmorton is starting off with a positive reputation.
I have a set similar to the first one you posted. I'll take some pics here in a little bit. I actually had to cut them down to fit the larger tires on my truck. So they aren't mounted how they were originally but they are close.
I have mine tucked up close to the body, and like the ideal of the drop steps.
Old 06-21-2014, 11:54 AM
Right on, so yours are mounted to the frame?
Old 06-21-2014, 05:18 PM
glovemeister glovemeister is offline
glovemeister is gaining momentum as a positive member of FTE.glovemeister is gaining momentum as a positive member of FTE.
I'd bolt to frame before I'd weld them.
Old 06-21-2014, 05:32 PM
Ether-Or... Just not body mount...
Old 06-22-2014, 12:20 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE has a good reputation on FTE.MOOSE_MACHINE has a good reputation on FTE.
I second the bolt
Old 06-23-2014, 12:17 AM
So I'll rephrase, does anyone have bolt to the frame OR welded on steps/nerf bars they want to share?
Old 06-23-2014, 01:06 AM
Quote:
Ive got bolted to the body that have frame "braces" basically a piece of square tubing with a flat plate that meets the frame for extra strength. Essentially the body mounts hold it up and the braces take the weight when I step on them.
I originally had just frame mounted, bolt on and I had way too much deflection. I used factory holes in the frame.
Old 06-23-2014, 08:44 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
I'm subscribing as that is exactly what I intend to do on my truck. I want to ditch these aluminum steps on the front doors and either buy or build a set of steps like the N-Fab steps and attach them directly to the frame. I've never been a fan of how they just bolt to the rocker panels. One thing I have heard about the N-Fab steps is that they tend to contact the bed when the frame flexes, so if you attach them to the frame, I would think you would want to leave a little additional room. I guess that begs another question... If the frame flexes enough to allow the rocker-mounted bars to contact the frame, does the frame flex enough to gnarfle the bars if they're bolted to the frame?
Here are some N-Fab step truck **** pics just for good measure:
Old 06-23-2014, 09:40 AM
Hey sorry I never got around to taking any pics this weekend. I'll be honest I forgot about it. I'll take some this evening when I get home. But yes they are welded to the frame.
Old 07-19-2014, 11:05 AM
Still love to see those if you've got a chance..
Old 07-19-2014, 11:09 AM
I saw a fella this week on my way to work who had a cclb lifted in pretty nice shape; rare here in Maine so I stopped to talk to him. He had the full length N-Fabs and they had been contacting the bed bad enough to push the quarter @ the leading edge of the bed up a little at the bottom. I figure do a two piece like I have now so they move independent of each other. Know what I'm sayin?
Old 07-19-2014, 11:55 PM
Gicknordon's Avatar
Gicknordon Gicknordon is offline
Gicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to all
I made my steps mounted to the frame. The plan was originally to make them power extending steps, but when i looked at the cost i decided it wasnt worth it and just made them solid steps. The angle i made them was supposed to make them hidden when the doors closed but come out and down when they open. I welded them in about the middle of what the travel would have been. I used two pieces of 1/4 in plate and sandwiched the frame and bolted above and below the frame. Way more solid than the tube steps that were on it before.
Old 07-21-2014, 09:17 AM
Brian on here has a set of N-Fab bars on his CCLB that don't extend past the back of the cab. They look reeeaal nice! Here's a pic from RRE this past weekend.
Old 07-21-2014, 09:28 AM
I like the N-Fab stuff; wouldn't be too hard to mod those to mount to the frame..
Does anyone make frame mount wheel to wheel side steps or nerf bars? GuitarJesus 1987 - 1996 F150 & Larger F-Series Trucks 4 Yesterday 07:21 PM
Running Board, Nerf Bar, Rocker Guard, or Step Suggestions 17CCLB250 2017 Super Duty 14 01-10-2017 03:05 PM
Considering N-Fab steps Fastback460 1987 - 1996 F150 & Larger F-Series Trucks 3 03-10-2016 07:50 PM
Looking for frame mount running boards or nerf bars SoCalAngler 1987 - 1996 F150 & Larger F-Series Trucks 17 09-10-2015 06:38 AM
Bricknose Prerunner light bar sources? lvin4jc 1987 - 1996 F150 & Larger F-Series Trucks 3 10-08-2011 10:07 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
