"Welded to the frame" nerf bars, anyone have some?
Not at all and the way those are fastened to the sills, I'm not sure it would even be necessary. They have a "block" for lack of a better term that fits into the square section on the bottom of the rocker and there are 6 bolts that go down through the rocker and into the mounts. They're solid. Brian said he thought he might have to add some bolts back through the vertical rib under the cab, but they were so solid he never bothered. I took pictures in case I decide to build my own.
Personally, I bought the cab length N-Fab bars necause I was worried that the wheel to wheel length ones would do some damage with the frame flex. I thought I wanted them in stainless, but they were not available for the OBS in cab length stainless. I got the black powder coated ones. "ALOT of $$$ ?? 4wheelonline.com has them for $369.00 that is where I got mine
Well at least not to do it the wrong way.. I've seen plenty of rocker guards land on bolders and not move. That being said I'm convinced that bolting them to the frame is the way to go.. I'd still like to see some...
That is a days pay to me. So I would rather build them from scratch and have them the way I want and NOT have them bolt to the body
I'm subscribing as that is exactly what I intend to do on my truck. I want to ditch these aluminum steps on the front doors and either buy or build a set of steps like the N-Fab steps and attach them directly to the frame. I've never been a fan of how they just bolt to the rocker panels. One thing I have heard about the N-Fab steps is that they tend to contact the bed when the frame flexes, so if you attach them to the frame, I would think you would want to leave a little additional room. I guess that begs another question... If the frame flexes enough to allow the rocker-mounted bars to contact the frame, does the frame flex enough to gnarfle the bars if they're bolted to the frame?
Here are some N-Fab step truck **** pics just for good measure:
