Transmission's
Transmission's
Hey guys, new here. I own several 9th generation F series. Currently just bought '94 1/2 F-250 with 7.3 turbo. My question is will a transmission out of an '01 Stroker bolt up to my '94? If not, are bellhouseing abel to swap ? Or just get new TC and rebuild kit and be done? Thanks, any information will be appreciated
Your converter has four studs. The newer converter has six. I think you can swap the flex plates so that it will bolt up.
I think there are some differences in the wiring to the solenoid body. I don't have wiring diagrams to be able to check, you'll want to look into this.
There is an orifice in the pump body that controls the torque converter lockup speed. The 4R100 in the 2001 has a 0.250" hole, your trans has about a 0.030" orifice. If you leave the big hole there when the converter locks it will SLAM on. It isn't pleasant.
No, you did not. The last year the E4OD was produced was 1998. The 2002 has a 4R100. See above.
Diesel 724
10-20-2015 01:10 AM
nintey4f150
04-01-2014 10:54 AM
