Vintique Steering wheel 1967 - Ford Truck Enthusiasts Forums
Old 06-20-2014, 08:16 PM
Sam's1967 Sam's1967 is online now
Sam's1967 is starting off with a positive reputation.
I recently purchased an ebay special steering wheel for my 67' F100. The make was Vintique. In any event, I was pretty excited when it arrived. I attempted to install the wheel but it would not go all the way down. Anyone else have the same problem with the Vintique wheel? Supposedly, it fits a bunch of F100 years and some Falcon, I believe.
Old 06-21-2014, 08:58 AM
crazed87bronco's Avatar
crazed87bronco crazed87bronco is offline
crazed87bronco is gaining momentum as a positive member of FTE.
Haven't looked into these steering wheels at all but did you check for the right spline count for the shaft and wheel? Any taper or damaged splines? They could stop it from going on the whole way. Is the wheel hitting the turn signal, horn mechanism or anything else not allowing it to slide down the shaft whole way. Just some things to check also check the bore diameter.
Old 06-21-2014, 10:41 AM
orich's Avatar
orich orich is offline
orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.
The spline count should be 36x and shaft size is 3/4" if this is correct then like crazy bronco says check that the blinker return finger tabs are aligned so the wheel hub seats..
orich
Wheel Vintiques Gennies dlb.motorman 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 08-02-2015 06:25 PM
53 F100 Tire Suggestions DDeffes 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 06-16-2015 07:11 PM
Wiring Assembly for headlamps/parklams 1967 F100 Sam's1967 1967 - 1972 F-100 & Larger F-Series Trucks 3 05-28-2015 06:01 PM
Trouble with Wheel Vintiques Gennie Innies 49willard 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 09-23-2014 07:41 PM
16in wheels / tires Shadowrider123 1961 - 1966 F-100 & Larger F-Series Trucks 4 07-24-2014 01:35 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
