Dump HPOP question - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Dump HPOP question
Old 06-20-2014, 04:34 PM
Robbieo11's Avatar
Robbieo11 Robbieo11 is offline
Robbieo11 is starting off with a positive reputation.
Dump HPOP question
[What does it pump or diesel. Yes diesel is an oil does it pump diesel?
Reason i ask is i am replacing the o rings $1.01 each at international. While it is draining i see motor? Draining out of the ports. Is this an indication there is other issues?
Thanks
In advance
Old 06-20-2014, 05:09 PM
Brain's 97 Diesel Brain's 97 Diesel is offline
Brain's 97 Diesel is starting off with a positive reputation.
HPOP is a high pressure oil pump, that pumps motor oil (not diesel fuel) at high pressure, which is used to fire off your diesel fuel injectors.
Old 06-20-2014, 05:52 PM
Robbieo11's Avatar
Ok got it
Another ? Why was fuel consumption so high 1/4 tank for 10 miles did it just dump the fuel into the cylinders? Oil level is ok i do not see where oil has dropped that much
I assume i will need and oil change now correct?
Old 06-20-2014, 10:01 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Diesel usage wouldn't have anything to do with the hpop. Are you sure you didn't blow a braided fuel line?
Old 06-20-2014, 10:04 PM
Robbieo11's Avatar
O ya blew sprayed onto the hpop and was bouncing off. Kinda glad it did thefittings on hpop where loose and leaking the return hose is shot drivers side pass side is not much better so trying to find replacements online now
Old 06-20-2014, 10:16 PM
I think riffraff has the braided fuel lines. I know they have the high pressure oil lines. You can send Clay an email or call if you can't find them on his site.
Old 06-20-2014, 10:20 PM
I believe I have my fuel lines in the shop if you would like. I converted to electric fuel so have no need for them. Of course no guarantees, they had 150k on them, but didn't leak at all.
I don't know if you have enough posts to pm me, but if you are interested and can't, email me. 427fordman at gmail.com No spaces in the address, and at replaced with @. I can send them out monday.
Old 06-20-2014, 10:43 PM
fordpride's Avatar
fordpride fordpride is online now
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Water in fuel already drained keeps coming back ssoulis 1999 - 2003 7.3L Power Stroke Diesel 13 01-11-2016 10:48 AM
Easy Question: Do I have to drain the motor oil when uninstalling the lift pump? genscripter Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 04-05-2015 11:10 PM
Help..... Fuel leak. Tdoyle03 1994.5 - 1997 7.3L Power Stroke Diesel 7 04-01-2015 03:05 PM
Fuel system knowledge BoomerTexas70's 1994.5 - 1997 7.3L Power Stroke Diesel 10 02-27-2015 08:42 PM
Water in fuel pickle40 6.0L Power Stroke Diesel 20 02-07-2015 12:35 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
