What do you attribute that to? Is that a domestic manufactured brass float, or a golly-knows what pot-metal deal? If the former I'm figuring it's due to ethanol??
If you hook an ohm meter up to it you should get some kind of a reading as you raise & lower the float shouldn't you. I am getting nothing so I guess I have more problems than the float.
Got another truck so I may pull the float gage and check what I get on it with an ohm meter.
TractormanBill
