Does this look INFECTED to you?
George
I have an HEI to go in, last time I tried it, I couldn't get it to set all the way in, was either the o-ring, or those thermostat vacuum switches, so when I get the thermostat housing off to put in a new t-stat, I'm getting rid of the one in it, going with a plug, then going to try it again. I have to run a new ignition wire, to get rid of the resistor on it, give the coil 12 volts.
Actually this IS an electronic ignition (ie no points) Ford's EEC-1 (the same ignition box is in my '78 Jeep CJ)
Roughly 60k miles on it by my records and that buildup (rather than erosion) had continuity, must be a form of carbon. That cap and rotor are Standard ~ Blue Streak parts, no longer available in my area having to drive 50+ miles to find. The gap on the plugs .44 is correct for the '81 300cid motor. Just for fun I checked the used plugs and they were all close.
Cartel
17
07-24-2019 04:21 AM
Hackerdcd
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
12-07-2015 10:05 AM
GamerGirlAlice
09-13-2013 07:50 AM
