State Inspection. - Ford Truck Enthusiasts Forums
North Carolina Chapter Join Chapter, Leader:ncheavymetal
State Inspection.
Old 07-08-2003, 09:45 PM
bosshoss bosshoss is offline
bosshoss is starting off with a positive reputation.
State Inspection.
Hey anybody out there.
Hellooooooooooooooooooo. Well anyway, just wanted to pass a little info your alls, Yalls way. If you have a battery change, or disconnect the battery, drive your truck awhile before you take it to get an inspection to reset the computer. Drive intown and on the highway, stop and go as well as cruse at highway speed. It might save you a failed test, or system not ready for testing failure prob.
Old 07-09-2003, 06:03 AM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
State Inspection.
Hi Dave, Wont leaving the battery disconnected for 24 hrs. do the same thing?
John
Old 07-09-2003, 11:07 PM
State Inspection.
Hey John.
Yes disconecting the battery will upset the computer. What i should have put in the note, was that you should give the computer a chance to relearn its settings by taking a drive after repair work is done. Then take your truck to have an emissions inspection done where the truck is now pluged into computer to check for codes or problems. A day or two after seems to be good.
Old 07-10-2003, 06:22 AM
jowilker's Avatar
State Inspection.
That is what I had heard, my 66 F100 can't even spell computer.
John
Old 07-10-2003, 07:40 AM
Bob Ayers Bob Ayers is offline
Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.
State Inspection.
If the KAM memory in the PCM has been reset (cleared) by
a battery disconnect, this will show up when they do the OBD-II
scan for the emissions test. So, after a battery disconnect, it's
a good idea to reload the KAM memory by driving it a while
before going in for the emissions test, like Boss said....
Old 07-11-2003, 07:07 AM
jowilker's Avatar
State Inspection.
Hi Bob, I weren't disagreeing, I'll meet you at the watering hole on Guess rd and drive my 66 this time. I'll buy if you can show me that stuff on the 66. LOL
Now my red Taurus truck is a different story.
John
Old 07-11-2003, 07:30 AM
State Inspection.
John
Sounds like a plan John, this time I'll drive my 61......
PA emissions, 5 Star and me D8chumley 2009 - 2014 F150 20 04-28-2013 07:56 AM
Need Help Understanding Texas Inspection/Emissions cougarman001 Texas Chapter 9 01-08-2012 12:15 PM
Passing Emissions Trick Dexterwho Ranger & B-Series 0 02-06-2008 07:22 PM
Trans flushing intervals ExpySport Expedition & Navigator 7 12-06-2007 05:12 AM
Will one converter pass Emissions testing/Inspection blackened 1978 - 1996 Big Bronco 22 04-04-2006 10:31 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
2002, battery, disconnect, disconnected, disconnecting, drive, f150, failed, ford, inspection, nc, obd, reset, state
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
