Still looking for advice on a 4.6 - Ford Truck Enthusiasts Forums
Old 06-19-2014, 05:52 PM
Bartramk Bartramk is offline
Bartramk is starting off with a positive reputation.
I'm still looking for some advice about my 01 f150 it has a 4.6 in it. I've recently changed the spark plugs and coils and a fuel filter. It still sounds like it has a miss to it and it stutters while in regular drive gear. Any advice?
Old 06-22-2014, 09:01 AM
70f100longbed's Avatar
70f100longbed 70f100longbed is online now
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
Could have cracked a plug, left a coil or injector connector loose, or have low compression on a cylinder.
advice on 2001 4.6L engine problems and swap MSwitchblade 1997 - 2003 F150 3 07-17-2015 11:57 AM
Advice on 2001 4.6L engine problem and swap MSwitchblade 1997 - 2003 F150 2 07-15-2015 11:55 PM
97 f150 4.6 sohc to 4.6 dohc swap need help memphis_made 1997 - 2003 F150 2 12-05-2014 08:42 AM
Has anyone put a 4.6 in a 1959 F100? Choptopjimmy 1957 - 1960 F100 & Larger F-Series Trucks 5 08-02-2013 02:47 PM
4.6 to a 5.4? Chrisrob71 1997 - 2003 F150 17 01-12-2007 10:20 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
