Which tune up specs to use?? - Ford Truck Enthusiasts Forums
Old 06-19-2014, 02:00 PM
Trackerrrr's Avatar
Trackerrrr Trackerrrr is offline
Trackerrrr is gaining momentum as a positive member of FTE.
My '83 F350 has what I thought was the original 460 engine. However I discovered a sticker on the driver side valve cover while cleaning the grime off. It says it conforms to 1977 emission standards while leads me to believe it's a 1977 engine that was swapped into the truck. Which tuneup specs should I use? The engine decal or the radiator support decal??
Under hood decals? GuitarJesus 1987 - 1996 F150 & Larger F-Series Trucks 2 03-30-2016 09:27 PM
FTE Decals? z31freakify 1999 - 2003 7.3L Power Stroke Diesel 6 09-20-2015 07:49 AM
Decal removal ltlblutrk 1999 to 2016 Super Duty 5 05-12-2015 04:30 PM
4X4 Decal Removal on 2012 SD Dually 1999 to 2016 Super Duty 2 12-20-2014 12:39 AM
13" Camo Oval Decal doghouserez Appearance & Dress-Up 0 08-18-2014 10:36 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
