Clear coat over oil based? - Ford Truck Enthusiasts Forums
Paint & Bodywork SPONSORED BY:
Old 06-19-2014, 12:43 PM
greenwoodford's Avatar
greenwoodford greenwoodford is offline
greenwoodford is gaining momentum as a positive member of FTE.
I have a trailer frame that I had reinforced and then I painted it with Rustoleum oil based paint. I thought it would be a good idea to have a clear coat sprayed on it to protect the paint before I put decking on it. A couple body shops told me their clear coat won't work with oil based non automotive paint. Is there something out there that I could use or should I just let it be and put the deck on it? Thanks for any help.
Old 06-23-2014, 01:20 AM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
I think you can use any oil based paint but you will have to surface sand 1st.
Old 06-27-2014, 06:32 AM
yetiman38237's Avatar
yetiman38237 yetiman38237 is offline
yetiman38237 is gaining momentum as a positive member of FTE.
Did you put hardener in the paint you put on? Usually will hold up nicely if you do.....I bought some of that rustoleum at Wally World to do a deck table. I have some hardener I got at rural king for their oil based paint but haven't had a chance to spray it yet. I never noticed if they had clear coat in oil base.......
Old 06-27-2014, 07:55 AM
I didn't put any hardener in it; just rolled it straight onto the trailer from the can.
Old 06-27-2014, 10:17 PM
I sprayed a trailer with oil based paint I got at Lowe's. I didn't use hardener and sprayed 3 coats on only waiting about 20 mins between coats.....it took about a year sitting in the sun to dry completely lol. After reading the directions you are only supposed to put on one coat every 8 hrs.....
Paint color decided Jafo56 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 09-19-2016 07:09 PM
Clear coat seperation ojh Paint & Bodywork 2 06-03-2016 03:11 PM
Painting door handle rvpuller Paint & Bodywork 1 12-07-2015 08:10 PM
painting dilemma lafermedavid 1973 - 1979 F-100 & Larger F-Series Trucks 22 08-12-2013 11:26 PM
House Of kolor Paint Magic Paint & Bodywork 2 03-12-2008 11:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
