Concerned about my EOT/ECT spread after all the work Ive done - Ford Truck Enthusiasts Forums
Old 06-18-2014, 09:08 PM
Paulsf350sdcc's Avatar
Paulsf350sdcc Paulsf350sdcc is offline
Paulsf350sdcc is starting off with a positive reputation.
My spread before was 9-10 and now is steady at 12-13.
I changed the HPOP, oil cooler and screen, ICP, IPR, EGR cooler deleted, 4 inch turbo back exhaust and Atlas 40 FICM tune.
Any thoughts/help is appreciated.
Paul
Old 06-18-2014, 09:14 PM
diesel_dan's Avatar
diesel_dan diesel_dan is online now
FTE Addict
diesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to behold
Did you flush the coolant system prior to the work? Is it the original coolant pump?
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Are your oil anc coolant temps the same after a "cold soak" overnight?
Also - did you install a ford oil cooler?
Old 06-18-2014, 09:17 PM
Yes and yes. Ford oil cooler and coolant flush right before I did the work. Now has ELC in it with distilled water.
I'll let you know on the cold soak tomorrow since I just started driving it for real today.
Boy is this truck fun/fast with the Atlas 40!!
Old 06-18-2014, 09:18 PM
I don't know if its the original coolant pump. Bought the truck at 152K miles and now has 206K. Didn't have any problems with it before though even towing 11k 5th wheel.
Old 06-18-2014, 09:26 PM
diesel_dan's Avatar
FTE Addict
What are your absolute numbers? Are they similar to before? Have you changed the degas cap ever? how about the thermostat?
Old 06-18-2014, 09:30 PM
Oops, forgot about the T-stat, I changed that also.
The EOT before would be in the upper190s with coolant in the upper 180s.
Now I have EOT at 212-213 with ECT at 190-192.
The EOT holds at 212-213 from 60 MPH to in the low 70's
Have not changed the cap yet either.
Old 06-18-2014, 09:38 PM
jswartz84's Avatar
jswartz84 jswartz84 is online now
jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.
You could try taking the oil filter back out and making sure it seated correctly. Is ot an OEM oil filter?
Old 06-18-2014, 09:42 PM
diesel_dan's Avatar
FTE Addict
Quote:
^^^^ Ditto, are you thinking oil bypass sticking?
Old 06-18-2014, 09:54 PM
OEM filter
Old 06-18-2014, 09:57 PM
diesel_dan's Avatar
FTE Addict
Quote:
Originally Posted by Paulsf350sdcc View Post
OEM filter
and stock oil filter cap too?
Old 06-18-2014, 10:01 PM
But of course! :-) I listen to what is said here. lol
Its a brand new filter and oil. We have a 550 mile camping trip coming up at the end of July so I need to get this resolved soon. Appreciate all the help.
Old 06-18-2014, 10:02 PM
jswartz84's Avatar
Quote:
That's what I'm thinking.
Old 06-18-2014, 10:06 PM
Ugh...after all this work I am burnt out on this thing and out of money. I do not want to tear it apart....Is there a way I can tell for sure that its the bypass?
Old 06-18-2014, 10:23 PM
bismic's Avatar
I would verify the cold soak temps before worrying too much. If it is 12-13 degrees (at the proper test conditions), then that is not good, but it isn't a big enough problem to require immediate action.
Dorman 6.0 Trans cooler?? AllaboutMPG 1999 - 2003 7.3L Power Stroke Diesel 11 02-24-2016 06:32 PM
BPD Style Oil Cooler Remote Mount Kit billbot 6.0L Power Stroke Diesel 49 12-27-2015 11:51 PM
Oil cooler imminent? Aune163rd 6.0L Power Stroke Diesel 6 04-28-2015 03:36 AM
ECT-EOT Spread With EGR Cooler Delete or High Flow EGR Cooler Excurvelle 6.0L Power Stroke Diesel 4 03-18-2015 10:14 AM
Another oil cooler thread-deltas really matter with egr delete? Nitrodude 6.0L Power Stroke Diesel 66 02-07-2015 06:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
