Is my fuel pump going bad?
A lack of fuel condition should (in theory) cause P0172 and P0174 (System too lean B1, System too lean B2) codes. There will also typically be a noticeable loss of power as engine speed and load increases, or after driving some time and the windings inside the pump motor heat up and expand.
I just wanted to let everyone know it was the the pump I put the old regulator back on it was good and got my money back on it. I replaced the Front tank fuel pump,with old pump I was getting 42psi to 43psi Max. I installed the new pump (it had the factory one in it still 131K) I now have 52PSI and holds on the front tank.The rear tank still needs replaced it get 49psi and drops so the check vavle is bad.
Thanks for everyones help!
albacore26
05-10-2012 08:55 PM
Feo
49
04-05-2011 05:28 AM
EXPL4X4
03-22-2006 10:33 AM
rsrxc700
04-05-2002 08:49 AM
