Oil Leak from HPOP fitting
Here's my problem... found the leak in the valley of death, it's coming from one of the fitting on the HPOP where the line attaches, but it doesn't look like it's coming from the hose, looks like it's coming out of the fitting itself.
Here's a pic:
Any thoughts or suggestions?
I'm trying to sell my 2wd trans so that I can upgrade to a T500 and put new lines on all at once...
Here's a pic:
I meant to say the 'flare' was cracked. The local machine shop fixed me up with a new one, I should have gotten two new ones .
Get the Ford or International o-rings! I have tried to fix leaks on the HPOP before with just some plain o-rings and they never last. Sometimes a day, sometimes a week. But they never last. Use the ford o-rings, and follow the directions for the repair. They have an o-ring kit that covers the HPOP fittings, and the serviceable plug on the back. Using the tool from Riffraff would help, but not necessary. You have to push down on the fitting, then pull the hose out. Be sure to push down on the fitting first! What I find amazing, is how loose that fitting is when the engine is shut off, and it doesn't leak! When you grab that line when it's running, it tightens up really tight.
