F-750 front axle (size/dive option)? - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 06-18-2014, 05:13 PM
Fullsized-Fan Fullsized-Fan is offline
Fullsized-Fan is starting off with a positive reputation.
Hi,
is it true, that ford now offers the F-650 and F-750 with a driven front axle? Or is it still necessary to remove the stock axle for a driven one?
In either case, is the driven front axle (series, or the seemingly usually military replacement) the same width than the rear?
In case of the F-350-550, the raer axles was typically a bit wieder because of the dual-wheels, is it the same with the bigger trucks?
So if you switched to single rear like the military or earthromer did, would that effect the general width of the truck?
The stock version is 96.4 in width, would be quite handy if this could be reduced a little by switching to single rear wheels and a driven front alxe. (of course with offroad tires you might end up at 96 or above anyway)
Greetings
Old 07-10-2014, 08:08 PM
vintage56's Avatar
vintage56 vintage56 is offline
vintage56 is starting off with a positive reputation.
No answer on the 4-by question, but 96.4" width on the front axle width?!
I've been trying to research later model F-650/750 drive train to find a suitable replacement for my 56 C series truck. The '98 bow tie chassis currently under it (as acquired) is a non-starter.
Not to hijack, but how did you find front axle track width? I need something that's relatively within the 88" confines of my front fender spread...
Stoooopid Dually Questions BruteFord 1987 - 1996 F150 & Larger F-Series Trucks 74 08-21-2016 10:55 PM
03' F550 4x4 axle widths delta charlie 1999 to 2016 Super Duty 0 07-24-2016 09:01 AM
1992 SRW axle to DRW axle swap Dan_Johnston 1999 to 2016 Super Duty 1 01-26-2016 08:57 PM
To get an old F-550 to the F-250 dimensions? Fullsized-Fan 1999 to 2016 Super Duty 16 04-22-2014 03:57 PM
When do you think Ford will go boxed on the SuperDuty Lineup? Fullsized-Fan 1999 to 2016 Super Duty 31 03-18-2013 05:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
