Transit from E-Series: A Look into the New Ford Transit Vans - Ford Truck Enthusiasts Forums
2014+ Transit 2014+ full size Ford Transit Van, Wagon, Cutaway and Chassis-Cab
Old 06-18-2014, 02:46 PM
Ford-Trucks Editors Ford-Trucks Editors is offline
Host
Ford-Trucks Editors is gaining momentum as a positive member of FTE.
http://www.f150online.com/wp-content...ordTransit.jpg
When Ford announced that the E-Series vans were to stop production and be replaced by the European built Transit, many wondered if it was going to be as capable. With three different engines, three different roof heights, and three different cargo capacities; E-Series fans and users have nothing to worry about. The Transit will feature more capability, better fuel economy, and will also feature the new 3.2 liter Power Stroke Diesel!
Get the full details over on the blog here!
Old 06-23-2014, 12:43 PM
78fordman's Avatar
78fordman 78fordman is offline
78fordman has a good reputation on FTE.78fordman has a good reputation on FTE.78fordman has a good reputation on FTE.
With a max trailer weight of 7500 lbs it would not be a viable option for me. Some of my equipment weighs over 10k plus the trailer. Right now I pull this with my E-450 with a 7.3 psd. This looks like a good service vehicle but lacks in the heavy duty construction market.
Old 06-24-2014, 07:39 PM
03 SVT VERT 03 SVT VERT is offline
03 SVT VERT has a good reputation on FTE.03 SVT VERT has a good reputation on FTE.03 SVT VERT has a good reputation on FTE.
Quote:
That's my problem as well. Payload numbers look fine, but the towing numbers took a hit. Especially for the diesel (4,600lbs). Right now we use diesel E350 vans and they can tow about double what the Transit diesel is rated for.
Our scissor lifts alone weigh 5,000lbs, and then you have to add the trailer. Way over weight for a diesel transit.
Not sure what we're gonna end up doing. It has to be diesel which doesn't leave us too many options, at least from Ford anyway.
Old 06-24-2014, 10:26 PM
EconolineFan EconolineFan is offline
EconolineFan is starting off with a positive reputation.
Why not just keep your E350s?
Old 06-25-2014, 06:56 AM
Quote:
We've already kept them longer then we usually do. Usually we rotate out work vans every 10 years. Most of them are 12+ years old now and are starting to show their age.
Old 06-25-2014, 08:20 AM
finn finn is offline
finn is gaining momentum as a positive member of FTE.finn is gaining momentum as a positive member of FTE.
There hasn't been a diesel Econoline for several years now, so you haven't lost anything with the new Transit.
Either an F series or a GM diesel van.
Old 06-29-2014, 03:18 PM
m-chan68's Avatar
m-chan68 m-chan68 is offline
m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.
THIS would be the perfect example of a market segment where voicing your opinion in writing (AND your cheque book) to FoMoCo is in huge order. IF enough such opinions are voiced, and loud enough one never knows what can be achieved. As far as I know, the E-Series is not completely dead. The cutaway versions of the E-Series will continue production for another few years. It is definitely a wait and see game. If sales of the E-Series cutaway vans continue at a steady pace, but the new Transit falls below expections, you never know what can happen.
Off topic a little, but I still remember what happened back in the day, when Ford had planned on discontinuing the Mustang for 1987, and the car intended to replace it ended up as the Probe. Well, as many Mustang enthusiasts voiced their opinions, putting it lightly, the `87 to `93 Mustangs came about, and sold like hot cakes. The Probe turned out to be an expensive lemon, all just because enough voices were heard, and thankfully Ford listened.
Old 07-03-2014, 05:48 AM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
I believe the new T-series will do great. People are resistant to change, especially a drastic one like this. I can see the E-series purists flocking to the GM twins but considering the current Nissan/GM joint venture on a small runabout van, I can see GM beginning it's migration towards a Euro van.
It makes sense. Around here, fleets are littered with the Sprinters and Mercedes vans running that sweet little diesel that can idle all day and give great MPG's.
Ford is late to the party.
Old 07-04-2014, 02:13 PM
jimrat jimrat is offline
jimrat is starting off with a positive reputation.
Here is a copy from the Ford towing specs. Looks like your 7500# towing requirement fall within the Transit range. Second to last column is the towing capacity.
Transit 150, MWB, Low Roof Van 129.9 8600 3.7L 3.73 10800 5500 3600
Transit 150, MWB, Low Roof Van 129.9 8600 3.7L 4.10 12125 6800 3600
Transit 150, MWB, Low Roof Van 129.9 8600 3.5L 3.31 11200 5900 3550
Transit 150, MWB, Low Roof Van 129.9 8600 3.5L 3.73 12600 7300 3550
Transit 150, MWB, Low Roof Van 129.9 8600 3.2L 3.31 10600 4700 3220
Transit 150, MWB, Low Roof Van 129.9 8600 3.2L 3.73 13500 7600 3220
Old 07-20-2014, 07:37 PM
Anomic Anomic is offline
Anomic is starting off with a positive reputation.
Hmm UPS bought a bunch of those "sweet little diesel" sprinters. The first batch of 20 at my building all went to the crusher in 5-8 years. Horrible cost per mile. Yes great mpg but frequent and expensive maintnance. Nobody ever wanted to drive them either funky driving position, flat steering wheel, aweful mirrors, and my favorite "traction control" that cut the motor speed drasticallywhen a wheel slipped. This caused you to loose momentum and then sitting on a side of the hill looking in those silly euro mirrors trying to slide back down backwards and start over. Worse vehicle ive ever driven proffesionally to include the old aerostars we had. Those sprinters would be the last vehicles left and people would only take them out if every single other truck was gone.
Btw the old ford and gm where kept to 20-25 years international and frieghtliners are around 15 years now and still run well. The new workhorse (gm) are garbage and falling apart already 5 years in. Bad suspensions and transmissions.
Old 07-20-2014, 08:27 PM
tseekins's Avatar
I'm a letter carrier for the USPS and I agree, some vehicles shouldn't be used as a constant stop and go delivery vehicle. UPS like any other courier service
is start and stop and jamming through the gears all day.
I'm seeing a bunch of Sprinters in the FedEx fleet and I wonder how they're doing. *** communications is migrating to the Mercedes and Sprinters and they basically idle all day and they seem to be holding up well.
Old 07-21-2014, 10:04 AM
star gazer's Avatar
star gazer star gazer is offline
star gazer is starting off with a positive reputation.
I am seriously considering one of these to replace my F250 PSD. Only a couple bare bones models at a local dealer but enough to give me a good impression so far. Would probably go the ecoboost but might consider the diesel.
I pull a small 3000 lbs Casita travel trailer so a 5400 tow capacity is fine for me. And the 250 version has a GVWR of 9000lbs so can handle a decent load. I did notice that if I went with 3.73 rear end that the tow rating jumps up to 7000. Anyone with the EB and 3.73 that can tell me about what kind of mpg you might lose over the 3.31?
Dean
Old 07-22-2014, 04:34 PM
4x4slik's Avatar
4x4slik 4x4slik is offline
4x4slik is gaining momentum as a positive member of FTE.
Everyone thought that Ford was bringing this over along time ago. Instead, we got the Transit Connect. Ford has really been behind on this. I have not heard good things about the GM van, and the costs of the sprinter. I am wondering what has taken so long, and why the punnie towing numbers. Vans, especially in the last few years are being used for construction and service. I can understand having something fuel efficient, but why not use the big diesel as an option? Not sure what they have been doing for the last 4 years.
Old 07-23-2014, 07:39 AM
The van market in the US is small, and Ford is not "bringing the Transit here". The van had to be completely re-engineered and qualified for the US market, and a plant had to be cleared and completely retooled.
That's a big investment for not a lot of sales dollar return, so I can see why it takes time.
Our instant gratification society sometimes gets ahead of us.
Old 09-07-2014, 04:04 PM
IndyFan IndyFan is offline
IndyFan is starting off with a positive reputation.
Got a brother with UPS, and he says the Sprinters were terrible for them. Got a next door neighbor who was in management with Fed Ex, says they love them. My brother says they haul heavier loads than Fed Ex, but I don't know if that's true.
I traded an '08 Chevy Express for a 2015 Transit XLT last week, (both 15 passenger vans), and I liked the Chevy. This new Ford, however, is in a whole different league, as far as comfort, power, and how it drives. Those old designs just can't compete in those areas. They have an advantage in towing, though.
If you don't like the demise of the Econoline, then vent toward Obama, not Ford. CAFE ratings are the biggest reason for the change. Get ready for more. That's why you see the new F150's body made out of aluminum, shaving 700+ pounds. What it lost in weight, however, will surely be more than made up in sticker price. Get ready to drop your pants if you buy a nicely equipped 2015 F150.
Compared with an E250 Tom 2014+ Transit 2 01-20-2017 02:22 PM
Ford Recalling 2015-2016 Transit Vans Over Stalling Risks DerekShiekhi 2014+ Transit 0 08-30-2016 11:17 AM
Ford Makes Functional and Technological Improvements to Its 2017 Transit Vans DerekShiekhi 2014+ Transit 1 03-14-2016 09:10 PM
Why dont we get the Transit Custom? tx2sturgis 2014+ Transit 7 12-02-2014 01:09 PM
Latest Updates? Club Wagon 2014+ Transit 11 04-06-2014 02:19 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
