Pull the heads to get to the lifters? - Page 2 - Ford Truck Enthusiasts Forums
Old 06-19-2014, 09:54 PM
lemonshindig lemonshindig is offline
lemonshindig is starting off with a positive reputation.
Well, maybe it's the damn IPR after all? At WOT, the duty cycle maxes out at 35% (It won't go higher) and I never see the ICP above 2300.
I'm going to dead-head the pump and see what's up there. But I'll check the harness for resistance from IDM to injector first.
Old 06-19-2014, 09:59 PM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Hah! Sounds like my truck! Mine will occasionally go above those pressures, but it rarely sees 2500 PSI. I've seen it spike the IPR to 45% or so just once and if the truck that good all the time I would be thrilled. I've changed literally every sensor on the engine to try and diagnose my issue. Hopefully you will have better luck than I am having. I think mine needs either a new HPOP or Injectors and since you have already done the injectors I'm thinking more and more that it may be the pump.
Old 06-19-2014, 10:05 PM
By the way, if you end up needing lifters or pushrods and don't mind used, I can hook you up with whatever you need for the price of the shipping. It'll take them a few days to get from OH to WA though. If you're in a hurry or want new parts, Riffraff Diesel would be your best bet since they're a lot closer to you and have the best prices and customer service on this kind of thing.
Old 06-19-2014, 10:53 PM
Well, since the compression came back mostly good, I pulled the IPR. One of the seals is bad but I'm not sure if I did that during disassembly or not.
Edit: Nevermind, apparently that seal is supposed to be split:
http://www.riffraffdiesel.com/ipr-complete-re-seal-kit/
Old 06-20-2014, 01:21 AM
I've learned two lessons that I'd like to share:
1) Even if your pin-out resistance checks come back fine between the IDM plug and the injectors, the truck still won't run if you don't plug it back in.
2) If you see an o-ring sitting in the valley when you have the IPR out, you should probably recover it. Then when you start the truck up and you leak several gallons of fuel in just a few minutes, you'll have it handy to put it back on the fuel pressure regulator where it belongs. If you don't recover said o-ring, guess what, you get to pull the bowl again.
-Matt
Old 06-20-2014, 08:40 AM
-Matt
Lol, life lessons... Sometimes the best lessons are the hardest ones.
Old 06-20-2014, 09:06 AM
cowmilker08's Avatar
cowmilker08 cowmilker08 is online now
cowmilker08 has a good reputation on FTE.cowmilker08 has a good reputation on FTE.cowmilker08 has a good reputation on FTE.
Quote:
Originally Posted by DIYMechanic View Post
I doubt that is the issue if the trouble started all at once, but just in case here is the IDM pinout:
http://www.ford-trucks.com/forums/at...1&d=1314836746
It wouldn't be a terrible idea to pull the connector off the IDM and ohm all the way through the wiring from the injector plug to the IDM connector.
I was thinking he bought the truck with the miss/smoke/low power issues, but I just looked back through this thread and that isn't apparent to me now. I must have mixed something else up with this thread.
Old 06-20-2014, 09:55 AM
I did buy the truck with this issue. I paid $1500 for this cherry 4x4 standard cab it and it came with a chord of firewood. The engine has fantastic compression.
Now if I could only figure out what's wrong.
Oil Aeration, Fuel Aeration, IDM.
That is the path I'm heading down now. I don't know what else it could be, unless the o-rings are indeed bad, or the injectors I got from Rosewood are bad.
Old 06-20-2014, 10:55 AM
Then I stand by what I said about injector wires being crossed where they're spliced with the new pigtail harnesses. Its free to check, it just takes time.
Old 06-20-2014, 12:00 PM
I'd agree that the wiring, IDM and maybe even the PCM would be the ones to start with.
Old 06-21-2014, 03:41 AM
I already checked the wiring, it is not crossed or shorted.
I'll get around to throwing another IDM on it when I can find one.
Thanks
-Matt
Old 06-21-2014, 02:11 PM
There is definitely a hole in the rubber line for the return line.
It looks like all of the hoses going to this bowl on the low pressure side are just run-of-the-mill black fuel hoses with screw-type clamps. I could replace all of them with more of the same and maybe fix an air leak. Who knows?
  #28
Old 06-21-2014, 04:50 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
You can use SR9? fuel injection hose. The blue factory stuff is rated for a lot more heat, but others have used the fuel injection hose.
  #29
Old 06-21-2014, 09:10 PM
Well I pulled the fuel bowl out and replaced all of the hoses. I used transmission oil cooler hose. The old hoses were all bulged and in very bad shape.
It didn't make a difference.
So I found a guy parting out a '99 powerstroke, drove an hour and a half to drink beer with him while I pulled the IDM out of his truck and plugged it into mine, revved it once and said "I'll take it!". I gave him $100 and my old IDM so that he can move his parts truck around.
It is night and day. I am in a very good mood.
Thank you everyone!
  #30
Old 06-21-2014, 10:21 PM
So wait, the IDM fixed it then?
Lifter tick that comes and goes? MAHinton Oil & Lubrication 12 02-02-2016 02:58 PM
heads bieng redone. please help. Zac2zac2 1967 - 1972 F-100 & Larger F-Series Trucks 26 12-02-2014 11:39 PM
Flat tappet lifter replacement timbersteel 1987 - 1996 F150 & Larger F-Series Trucks 3 10-17-2014 12:57 AM
Gotta replace lifters on 4.0 help rangergirl94 Ranger & B-Series 10 03-08-2013 07:03 PM
Lifter Won't Prime Lance Hogan FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 27 07-19-2008 10:41 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
